Finally getting the twins going..
Re: Finally getting the twins going..
Postby gobigorgohome » Mon Mar 22, 2010 2:09 pm
lookin good! i like the setup let us know the numbers when your all done. im intersested to know ur boost levels and egt's with both them turbos. :D
91 4x4 with the 727, has the factory tach!
Boost gauge installed 27psi, new exhaust manifold here just not on yet. Pyro installed all glowshift units. 173 HP baseline before poor mans 4 inch dp
gobigorgohome
Postby SNOOT » Mon Mar 22, 2010 8:55 pm
2nd gear roll on. 50 psi.. Also did a 3rd gear roll on at 55psi.
http://www.youtube.com/watch?v=Pz9QPlFsWPY
1993 W350
SNOOT
Postby cedardiesel » Tue Mar 23, 2010 4:46 pm
Yea your setup spools exactly like mine did too but you make the one cooler pipe smaller to 3 or 3.5in. it will make world of difference. I also noticed your not running a wastegate exactly why did you go that route just wondering. Just my opinion you would run a tighter exhaust housing on the small charger like a 12cm2 so you get quicker spool up and run an external wastegate on manifold like a tial 48mm so it would then take all the load off of small charger and send it all to the big charger after initial spoolup. just my two cents ;-)
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Postby mprmn08 » Tue Mar 23, 2010 5:49 pm
that thing seems like it sure takes off hard when the turbos lite. awesome man. keep givin us more video. :D
mprmn08
Postby SNOOT » Tue Mar 23, 2010 8:47 pm
cedardiesel wrote:Yea your setup spools exactly like mine did too but you make the one cooler pipe smaller to 3 or 3.5in. it will make world of difference. I also noticed your not running a wastegate exactly why did you go that route just wondering. Just my opinion you would run a tighter exhaust housing on the small charger like a 12cm2 so you get quicker spool up and run an external wastegate on manifold like a tial 48mm so it would then take all the load off of small charger and send it all to the big charger after initial spoolup. just my two cents ;-)
I am going to be taking some readings first with the current setup. Drive pressure, cold pipe pressure and decide what I need to do. I agree a waste gated housing may be in order. However the small turbo is a custom turbo from DDP. It has a pretty big exhaust housing on it and the wheel has been clipped to allow more flow.
I will get some readings and let you all know what the outcome is.
I would do this set-up all over again it was very easy IMO. Look at my first post thats when I started to todays date finished. I did it for around 1K not including the S300.
S400 turbo $495.00
Flanges $180.00
Tubing $240.00
Oil drains $50.00
Oil supply $40.00
Gaskets $40.00
Time
1993 W350
SNOOT
Postby SNOOT » Tue Mar 23, 2010 8:53 pm
mprmn08 wrote:that thing seems like it sure takes off hard when the turbos lite. awesome man. keep givin us more video. :D
Its amazing how cool it is under the hood with twins!
1993 W350
SNOOT
Postby cedardiesel » Wed Mar 24, 2010 7:44 pm
Ok I got ya. But honestly I wouldn't go with a wastgated housing i would do a nonwastegated 12cm housing and do an external gate that dump pressure into the hot pipe cause in doing it that way it takes almost a full load off of small charger and most on big charger and also doing it that way if you think your big charger lights hard now set it up like I explain and really hang on 8). I'm only sayin this all from experience from mine plus mine is p-pump setup i'm sure yours act much different. But I know once you get them dialed up best to your setup it will be right. ;-)
cedardiesel
Postby SNOOT » Fri Mar 26, 2010 3:30 pm
I have about 200 miles on the truck so far so good and it runs clean..
Todays finished photos.
1993 W350
SNOOT
Postby soggy » Fri Mar 26, 2010 3:39 pm
Looks great, planning on doing any racing this year?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby SNOOT » Fri Mar 26, 2010 4:16 pm
soggy wrote:Looks great, planning on doing any racing this year?
April 24th 1ST run down the track don't you know!!!
I will make a couple hard runs for sure.. I have to add my fuel tank bowl still and run my electric fuel pump direct to the pump still..
Fuel bowl that mounts to the bottom of the tank.
1993 W350
SNOOT
Postby soggy » Fri Mar 26, 2010 5:42 pm
Is that the date for NHRDA Bremerton event? I might have to come on up there and check it out.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby SNOOT » Fri Mar 26, 2010 6:01 pm
Sure is!!!
1993 W350
SNOOT
Postby SNOOT » Sun Apr 04, 2010 10:51 am
Here is a run down the freeway. The truck tops out real fast now. These pulls are done in overdrive WOT.
I put another 1/2 turn on my fuel pump. If I go any more I am going to have to change my indexing on the throttle shaft so I can idle it down.
In these runs I let out at 95MPH each time...lol Pretty sure I am over 100MPH cause I have tires 2 sizes larger :lol:
enjoy.
At 3:27 I was at 57PSI and 1,100EGT
http://www.youtube.com/watch?v=az8VedrjMG4
1993 W350
SNOOT
Postby bgilbert » Sun Apr 04, 2010 12:02 pm
Gonna need a bigger boost gauge! :lol: Use the 60psi gauge for the primary boost output.
Bill Gilbert
bgilbert
Postby SNOOT » Sun Apr 04, 2010 1:13 pm
lol yeah I have a 0-30 for the cold pipe right now.
1993 W350
SNOOT
