by JQmile » Tue Jul 15, 2008 11:55 pm
Ok, I've finally come up with a short term goal for the project. Still no idea how far I'll go with this thing in the long term. For short term, I'm going to see how far I can go with the stock parts, meaning long block, ve pump, and turbo. Going to do a compressor upgrade, put the 14mm h/r on, put in a fuel system, wrench down the head bolts, wastegate it, then spray it. I'm hoping for 500rwhp with nitrous on the stock head gasket through the 727 trans. I'm also thinking of putting a gear vendors OD in it to see how it helps on fuel economy I might switch to a 47rh, but the gear vendors would be cool for the 4.11 geared 5spd guys to see what kind of rpm drop/mileage gain they could get. Looking for 12s down the strip which should be more than feasable with a locker and slicks.
