INJECTOR CHART
Postby winkdemon » Sun Sep 07, 2008 10:55 pm
i found thAT they won't work in my truck there for a p pump :(
if fuel mileage matters u can't afford it lol
winkdemon
Postby winkdemon » Thu Sep 11, 2008 12:52 am
how bigg of injectors can u put in one of these truck . 93 i/c , i bought a newer truck so it is play time now ......
winkdemon
Postby bgilbert » Sun Sep 14, 2008 3:51 pm
Someone good with the math, Pie are squared etc, figure up me a 4 hole injector with the same cross sectional area as a 6 x .016 injector.
Bill Gilbert
bgilbert
Postby Begle1 » Sun Sep 14, 2008 4:03 pm
.0196
Postby bgilbert » Sun Sep 14, 2008 4:06 pm
Begle1 wrote:.0196
So a 4x18 or 4x20 would fit the bill?
I wonder how much Old Smokey, way back when, had his POD's hog out or burned out to??
Thinking about a 4 hole set being built from a stock nonIC'd nozzle with flow comparable to a 6x16.
bgilbert
Postby DTanklage » Sun Sep 14, 2008 6:07 pm
bgilbert wrote:
I wonder how much Old Smokey had his POD's hog out to ?
DTanklage
Postby 1991cummins » Mon Oct 06, 2008 7:46 am
i looked through the forum but i didnt see 370's from new era diesel?
anyone know the 370's size
1991cummins
Postby bgilbert » Mon Oct 06, 2008 11:29 am
1991cummins wrote:i looked through the forum but i didnt see 370's from new era diesel?
5x.012.
Bill Gilbert
bgilbert
Postby 92d250 » Thu Oct 23, 2008 10:50 am
How much more power/smoke will a 6x14 make than pod?
1992 D250 370,000 and counting on the cummins, auto, pump turned up, 6x16, 3200 spring, afc lever mia, boost and pyro guage, single stack, 5 inch lift, shifter with od button on it, potentiomitor..... Next hx40, 285's...
92d250
Postby DTanklage » Wed Nov 12, 2008 10:45 am
you will be adding an additional 50% worth of fuel if you switch from a pod to a 6x14
thats one way of saying it....
or you could say that your 6x14's are 33% bigger than a pod
depends which way you look at it
don
DTanklage
Postby dragrdan » Sat Nov 15, 2008 4:44 pm
What do the numbers (eg. 185 190 230....) relate to? A part number, or HP rating?
dragrdan
Postby dragrdan » Mon Nov 17, 2008 4:07 pm
Are the 185, 190, 230, 300, 330, and 435's "off the shelf" injectors? Are they just injectors for a different application/hp rating that uses the b series? If so, does anyone have part #s(bosch or cummins), or cpl #s, or application for them? Are they specifically for the first gen style engine(correct spray pattern, pop pressure, etc...)? I noticed that the 370's specifically say 2nd gen. I take it that they would take some mods to the injector to put em in a first gen or am I wrong?
Thanks for the info in advance
dragrdan
Postby TWorline » Fri Nov 28, 2008 1:44 pm
185 and 190 injectors are both off the shelf Bosch. Some of the rest are for 2nd Gen motors. Your best bet would be to get ahold of Chuck @ New Era Diesel and get a set of EDM injectors so you can stay with the 6 hole injectors that were designed for our trucks.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby pulltilbroke » Fri Dec 05, 2008 8:30 pm
So my 8x11s are comparable to what a 435?
Postby GLHS » Sat Dec 06, 2008 7:34 am
Yes.......
GLHS
