by Deathrod » Fri May 17, 2013 10:29 pm
Yup pegged my 60 psi boost gauge....whoops, probably not great on the stock valve springs. With stock injectors it would only push 40-45ish, so it's got more go. Didn't get a chance to watch the pyro...wot usually requires a passenger to watch, it's pretty violent and quick. I really think it needs higher gearing.....but ill deal with what I got.
On a side note with all this talk about thinner washers for the injectors, I noticed the 7-9mm adapters are the same thickness as the stock washers. Anybody make thin adapters?........hungry diesel....could be the first??? Corner the market on the 8 of us non ic guys!
