a crazzy dual fuel system
Postby ford69557ci » Sat Nov 17, 2007 4:41 pm
that engine has plenty of vac no matter what thanks to a 4 stg vav pump
ford69557ci
Postby cummins king » Sat Nov 17, 2007 7:03 pm
a electric fuel pump that pumps 40gph at 100psi is that crap, good or really good
what does the areomotive a1000 pump
thanks
93 4X4 auto
cummins king
Postby JD730 » Sun Nov 18, 2007 7:01 am
DTanklage wrote:cool, now we have some hard numbers to work with
40-120
50-120
that is what i was expecting
now, i wonder what happens to output when you get case pressure to 240?
hehe
I dropped a stock injector in there to fire it up and here the rest of them. Sounds good and ran smooth.
Case pressure as follows, its 33* outside right now.
Idle is 800 rpm
High rpm is 2300
No load
No KSB:
80psi
150psi
KSB on:
150psi
200psi
Mike
The "Rattle Box"
JD730
Postby KTA » Sun Nov 18, 2007 8:55 am
Now to get it under load and see the results. 8)
Postby DTanklage » Sun Nov 18, 2007 10:03 am
yea, brian is right
those are the numbers we need
33°
brrrr
DTanklage
Postby wannadiesel » Sun Nov 18, 2007 5:36 pm
Cool, I can't wait to hear what it looks like under load.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Begle1 » Sun Nov 18, 2007 6:01 pm
I'm surprised to see that much of a difference with the KSB on and off.
So you are turning voltage on to manually activate the KSB, right? And the earlier trucks need to turn off voltage to turn the KSB on?
I wonder if the earlier trucks have that kind of a change.
Postby JD730 » Sun Nov 18, 2007 7:59 pm
KTA wrote:Now to get it under load and see the results. 8)
Don't worry, in due time, good things should not be rushed.
wannadiesel wrote:Cool, I can't wait to hear what it looks like under load.
Sounds like a volunteer to watch the gauge while I watch the road.
Mike
The "Rattle Box"
JD730
Postby Begle1 » Sun Nov 18, 2007 8:15 pm
JD730 wrote:Sounds like a volunteer to watch the gauge while I watch the road.
You have the gauge mounted in the engine compartment?
Where is it tapped into?
Postby ford69557ci » Sun Nov 18, 2007 10:01 pm
:worthless: pics pics pics
ford69557ci
Postby JD730 » Mon Nov 19, 2007 5:06 am
Begle1 wrote:You have the gauge mounted in the engine compartment?
Umm, how would you read it when your driving? The gauge is mounted on top of my CB on top of the tunnel.
The injection pump. You'll see it in pictures when I take them one day.
ford69557ci wrote::worthless: pics pics pics
Now you want pics? What else do you want?
Mike
The "Rattle Box"
JD730
Postby Begle1 » Mon Nov 19, 2007 6:11 am
JD730 wrote:Umm, how would you read it when your driving?
With a volunteer of course. :roll:
Where at on the injection pump is it tapped in to?
Postby ford69557ci » Mon Nov 19, 2007 11:46 am
2 blondes 2 brunettes a sac of money maybe a yacht in the florida keys? is that to much to ask?
ford69557ci
Postby cummins king » Tue Nov 27, 2007 9:13 pm
hey JD730
have u got any underload psi info
thanks
93 4X4 auto
cummins king
Postby JD730 » Wed Nov 28, 2007 4:54 am
Nope, truck is still sitting in the shop on the lift about 4 feet in the air right now.
Mike
The "Rattle Box"
JD730
Users browsing this forum: No registered users and 67 guests
