Dual feed VE
Postby meby » Thu Oct 11, 2007 10:31 am
DTanklage wrote:
why do you think there is a need for 2 ck vlv's in same line?
I dont think it would be necassary. an extra safegaurd maybe.
no I dont have a pressure gauge installed at the case, these are just ideas that were bumping around in my head. :shock:
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby DTanklage » Fri Oct 12, 2007 9:13 am
i think everyone that is above 350 hp ought to have a case pressure gauge
jmo
would be nice if we could all compare numbers for one, and what better place to know if you have fuel or not?
don
i am not suggesting to do away with supply pressure gauge
DTanklage
Postby meby » Wed Oct 17, 2007 8:42 am
nobody going to touch this? I would like to hear what you all think. :)
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby DTanklage » Wed Oct 17, 2007 9:10 am
it would be simple enough to install
especially for the guys running the dual feed that are using the return for the 2nd inlet. just tee in to the supply line in what used to be the return side anywheres between ve and the check valve
for the guys that are still using the single factory supply it would mean removing the pump, drill and tap the left side, and get your reading there
the gauge would tell exactly what inlet pressure increases do to case pressure and will also be a good way to monitor the vane pumps performance and the affect of the ksb and the affect of the fuel screw and i think it would even be a tuning tool for those still running the afc
if i decide to stick with the ve i promise you i will have a ve case pressure gauge installed soon
don
DTanklage
Postby ford69557ci » Sun Oct 28, 2007 5:33 pm
what is the purpose of the check valve??? to keep case pressure from returning to the pump when pump is not running?
ford69557ci
Postby DTanklage » Sun Oct 28, 2007 7:31 pm
in this system it is to let the vane pump pressure over ride the elec pump pressure
so the case will see which ever is higher
DTanklage
Postby ford69557ci » Sun Oct 28, 2007 7:39 pm
it looked like the way meby was running the system that the pump would be off till a certain amount of boost so in that case it would keep case pressure from returning to the pump and when the pump was running it would let the ve receive which ever pressure is higher.
ford69557ci
Postby meby » Mon Oct 29, 2007 8:12 am
ford69557ci wrote:it looked like the way meby was running the system that the pump would be off till a certain amount of boost so in that case it would keep case pressure from returning to the pump and when the pump was running it would let the ve receive which ever pressure is higher.
Thats basically the idea.
also, it would allow us to retain the stock fuel system for reliability. 2nd, it might be an answer to the problem of the vane pump not being able to keep up with demand of the highest hp ve trucks.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby ford69557ci » Mon Oct 29, 2007 10:55 am
i am goin to try an a1000 and regulator for my primary system. i guess then i am goin to find i high pressure pump and try to feet into the shutoff for the secondary basically like the illustration
ford69557ci
Postby DTanklage » Mon Oct 29, 2007 11:35 am
you got the right idea aaron
keep us posted!
DTanklage
Postby ford69557ci » Mon Oct 29, 2007 12:38 pm
as soon as my cam plate is done the testing will begin :twisted:
ford69557ci
Postby DTanklage » Mon Oct 29, 2007 1:27 pm
no mercy
throw that mech pump you have on there and see what happens...
DTanklage
Postby meby » Mon Oct 29, 2007 2:54 pm
ford69557ci wrote:i am goin to try an a1000 and regulator for my primary system. i guess then i am goin to find i high pressure pump and try to feet into the shutoff for the secondary basically like the illustration
let me know how it works. I havent tried any of the above idea's, just internet egineering at this point. :shock: thanks
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby ford69557ci » Mon Oct 29, 2007 5:21 pm
i will try to video the pump on a stand. possible explosion???
ford69557ci
Postby DTanklage » Mon Oct 29, 2007 7:23 pm
well you will be the first to know about it if it does...
have fun!
DTanklage
