building atleast 400hp
Re: building atleast 400hp
Postby CumminsPower59 » Wed Feb 06, 2013 6:48 pm
DNR customs makes a kit...
Postby oldestof11 » Wed Feb 06, 2013 8:07 pm
Yep, one of the wires in the 3 wire connector is OD. It needs to be grounded iirc.
Postby vefummins » Wed Feb 06, 2013 8:11 pm
42 bucks I'll take it
vefummins
Postby vefummins » Wed Feb 06, 2013 9:03 pm
And since I got those 6x16s I'm thinking about running twins?I looked at the injector chart and they seem pretty big.what twin set up would be the best
vefummins
Postby CumminsPower59 » Thu Feb 07, 2013 9:19 am
Guys have had good results with S300's over S400's, HX35's over HT3B's, etc. There are many combinations of primary and secondary choices out there to make a good set of compound setups.
Postby vefummins » Thu Feb 07, 2013 10:36 am
I'm running a hx 35 right now.I can get an hx55 pretty cheap.would those be a good combo.im not worried about it being little bit on the hot side.just want enough air to get to 400hp.and for it to still spool decent
vefummins
Postby RCCUMMINS89 » Thu Feb 07, 2013 10:49 am
In order to match the air to a 6x16 injector, you'll want a 62 size secondary with a 475 size primary. Then you'll need in the upper 20s in timing..... With proper tuning that'll put you in the mid 400 range.
Postby vefummins » Thu Feb 07, 2013 3:29 pm
How much would that set up cost.like 3000?
vefummins
Postby oldestof11 » Thu Feb 07, 2013 3:33 pm
Stomp made nearly 900hp on an HX35 and BHT3B.
You can get the whole setup minus the HX35 which includes everything you need including a S400 or HT3B from Crazy Carl's turbo for $1250
Postby RCCUMMINS89 » Thu Feb 07, 2013 3:37 pm
What????????????????????????? THAT INCLUDES A PRIMARY?
Postby Sutter1stgen » Thu Feb 07, 2013 4:00 pm
Turbo Dave was selling s475 primary turbos for 650$ last I checked. So another 600 in pre bent piping sounds pretty reasonable.
Eric
Sutter1stgen
Postby RCCUMMINS89 » Thu Feb 07, 2013 4:08 pm
Well... I just looked at Crazy Carl's site and 1250 does not include a turbo.
I don't know of anywhere that you can get the piping for under 1200 (everything but the turbos)
Postby oldestof11 » Thu Feb 07, 2013 4:29 pm
I did that wrong. Crap...
Gonna take a nap before I snap.
Postby Mark Nixon » Thu Feb 07, 2013 5:33 pm
oldestof11 wrote:I did that wrong. Crap...
You trying to do lyrics for some new rap crap, or what? :lol:
Postby oldestof11 » Thu Feb 07, 2013 6:43 pm
More tired babble from the hard working rabble.
