RCCUMMINS89 wrote:Ya, I only tapped it down maybe.... MAYBE a .5mm I'll mess with it more once I have the adjustable doo dad on it.
RCCUMMINS89 wrote: allot better than the whack it with a sledge hammer way.
BC847 wrote:RCCUMMINS89 wrote:Ya, I only tapped it down maybe.... MAYBE a .5mm I'll mess with it more once I have the adjustable doo dad on it.
Another sporty little tool you can make would be like a modified socket, that would fit over the top of the regulator, turn it a little to engage those two wings, and have a long, fine-threaded shaft with a knob . . . .. so as to be able to manually, and with fair precision, run in the regulator as the engine runs.
revemup15 wrote:Umm i need a pic david
turboram wrote:Here this would kill 2 birds with one stone..... I propose a case regulator that is moved to the over flow valve hole and the old case pressure location be plugged this would ease adjust ability and remove the constant bleed BUT would also allow way more pump cooling because the fuel that was just recirculating and heating up would be sent in a return to the tank and cool, fresh and denser fuel will be available in the pump.....
team this up with an adjustable timing spring and spacer and I believe this would be a great performance mod
revemup15 wrote:turboram wrote:Here this would kill 2 birds with one stone..... I propose a case regulator that is moved to the over flow valve hole and the old case pressure location be plugged this would ease adjust ability and remove the constant bleed BUT would also allow way more pump cooling because the fuel that was just recirculating and heating up would be sent in a return to the tank and cool, fresh and denser fuel will be available in the pump.....
Ummm interesting....
oldestof11 wrote:Another thought is completely doing away with the return orifice and putting an adjustable flow control of some sort on it to keep the pressure constant and adjustable for any application.
You really don't need high flow when you are driving around, occasional romp on the go pedal, towing. But drag racing, dyno's, sled pulls all require high RPM's and the 14mm H&R for whatever reason, seizes when meeting with high RPM's...
turboram wrote:Pe pump overflow is regulated at one pressure.. so I dont see that working. More fuel is bypassed in the case pressure regulator than the overflow it starts opening at 50 psi the ksb counter acts this but up untill a set pressure in the ksb then opens, that pressure is unknown to me but I will investigate. I think that ksb pressure relief could be raised then no fuel could be bypassed at any rpm. Then the overflow orifice could be a on a wot switch to close it then all fuel that the vane pump delivers could be used. The other way would be to plug the case relief and overflow orifice and use a boost reference regulator set at 3 to 1 like a fuel injected car would use
Users browsing this forum: No registered users and 68 guests
