by ford69557ci » Sat Dec 29, 2007 3:28 pm
yes the vane pump comes apart at 75 or 80 and yes there is a slight difference in cc of fuel at lower pressure. i have it set at 68-70 now and have no problems other than keeping the shaft seal in. the 14mm h-r is doing fine i think the only reason anyone had any trouble with them was due to not havin enough fuel supply. i am just going to run the pro series pump only because with my large modified fuel inlet and all of the internal flow improvement it seems to be doing fine with the single feed. keep in mind though that the pump has only made it to 2500rpm due to the seal failure issues so at 5000rpm it may need the dual feed to keep up and that is somethin iwill figure out when i get the seal problem solved. as for whats ported in the pump??? everywhere that a drop of fuel can go has been worked on which included alot of extrude honing and that wasnt cheap.
