Re: Next stage- Twins (last page)
Postby Tacoclaw » Thu Jul 07, 2011 8:20 pm
Meh, I'm just gonna bump this as things get done.
Finished filling and matching my T6 flange:
Justin: Yeah, it hasn't moved. Nothing I work on stays in the same place as I work, but it's supposed to be in the same spot, and it's definitely in the same area as it started. :mrgreen:
Postby Tacoclaw » Fri Jul 08, 2011 6:03 pm
Hotpipe tacked up. We'll finish weld it tomorrow.
Postby AHineman » Fri Jul 08, 2011 6:09 pm
Not bad old buddy. 8)
Postby ahale2772 » Mon Jul 11, 2011 7:21 am
sweeeettttt!!!
idk if i missed it but what its the primary?
Postby AHineman » Mon Jul 11, 2011 8:06 am
171702 s475.
Postby Tacoclaw » Mon Jul 11, 2011 7:15 pm
Thank goodness for secretarys, huh?
I'll have that coffee now, Ms. Hineman. :lol:
*double checks the parts list Hineman gave me to make sure I won't need his help after that*
Also, fwiw, hot pipe isn't done yet. It pulled a little when we welded it, so I guess I'm gonna have to bite the bullet and weld the last cut while it's bolted up. I figure I'll make a "gasket" out of a pop (beer) can so no slag gets in the S400.
Postby AHineman » Mon Jul 11, 2011 7:26 pm
Keep it up...
I try to help and this is the thanks I get. :roll:
Don't worry, when you get done you'll have the 2nd highest horsepower VE truck in Gallia county. :lol:
Hint on the 1st...it's a green 2wd. :mrgreen:
Postby Tacoclaw » Mon Jul 11, 2011 8:02 pm
That's not saying much considering I'm decently sure we're 2 out of the 3 VE trucks in Gallia County. :P
I wouldn't be surprised to still be #3 to be honest, but who cares? I get to listen to twins. :mrgreen:
Postby JustinRhodes » Mon Jul 11, 2011 8:28 pm
AHineman wrote:Keep it up...
my truck aint green or 2wd? :lol:
JustinRhodes
Postby Tacoclaw » Wed Jul 13, 2011 3:47 pm
I guess he doesn't have much to say back to that, huh, Justin? :mrgreen:
You still need to get that new turbo on before you can hang with us though, the 5-speed just isn't enough any more. :P
Anyways, I cut my hotpipe and bolted both ends, so this should keep it from pulling next time it gets welded. I also pulled off the inner fender finally, so I can see what I'm working with in relation to drains. I think it'll be ok with a "T", but I'll have to get some miles on it to see. It did allow me to get some better pics of the layout:
The plan is to run the BHAF from the same location. Since I'll never have that S400 working to it's full potiental, I don't see any need to try hacking some odd filter in there yet. If it acts like it's chocking out on the dyno or something, I'll just pull the filter off of it. That blue silicone is temporary. SIS was out of the black ones, so that'll have to do until they restock. ;-)
EDIT: Justin, I just realized that as the only one with a running truck, you don't have much keeping-up to do at all. :mrgreen:
Postby AHineman » Wed Jul 13, 2011 6:06 pm
JustinRhodes wrote:my truck aint green or 2wd? :lol:
I know, it's a blue 4wd with one turbo. :P
(that will outrun my driveway dweller right this moment. :sad: )
@Taco
Looks good. Before you weld the hotpipe, I would bevel the edges of the pipe like the weld elbows were to begin with.
Should be fun to have two twins trucks cruisin' Gallipolis.
Postby Remps » Wed Jul 13, 2011 8:21 pm
What size of turbine wheel is on that S475?
Postby JustinRhodes » Wed Jul 13, 2011 8:21 pm
my m&h timing kit and 366 spring will be here tomorrow, all the stuff for the piston lift pump got here today.
so after i get that done the next couple days its time for that turbo. i might need ya to give me a hand if you could with that turbo in a week or two because its a heavy sob.
And dont jinx me about my truck being the only one on the road, its about due to get towed home again :lol:
@ levi its looking like its coming along pretty good. it should be pretty mean :twisted:
JustinRhodes
Postby AHineman » Wed Jul 13, 2011 8:30 pm
Remps wrote:What size of turbine wheel is on that S475?
88mm
Postby Tacoclaw » Wed Jul 13, 2011 9:02 pm
Thank you, Ms. Hineman.
Yes, that will be all.
