viewtopic.php?f=4&t=284&start=0
viewtopic.php?f=4&t=1505&start=90
dragrdan wrote:The RPM's you have listed, are they stand or engine?
PToombs wrote:Would it benefit to run a larger cam plate with the 12mm plunger and head? I've been wondering about this for a month or so and keep forgetting to ask.
KTA wrote:Yes I plan to make a special Tee banjo fitting so that I can monitor case pressure before the orificed return banjo. My other option is to make a fitting to get the pressure out of the fuel shut off solenoid port since I gut them to run anyway so I don't need a 12V power supply. I am conceraned that if I put it there though I will get a lot of pressure fluctuation form the plunger. decisions, decisions.......... Tractor pulling next weekend at Gordyville so that will probably put any more testing off for a couple of weeks as other stuff has now come up to do.
