Postby Tacoclaw » Mon Apr 30, 2012 7:08 pm
Damn...
"Let me Google that for you" :lol:
Postby Tacoclaw » Mon Apr 30, 2012 7:21 pm
Well, my Googling skills have failed. Link to the thread, Jesse?
Postby TheTowingCowboy » Mon Apr 30, 2012 7:26 pm
Lol well from my reading the reason D-Techs are cheap is cause its your basic S300 with are cheap turbos persay, they are proven and simple. D-Tech just makes custom 'Race Covers' which is what the inducer housing is called by some places, in house. So it should be a S300 that has a D-Tech custom made house.
EDIT: If I can find the link I will post it lol I have sthi luck of finding stuff once.
TheTowingCowboy
Postby TheTowingCowboy » Mon Apr 30, 2012 7:38 pm
Here is the link about where its a standard S300 cartridge so you can change wheels and such with other S300 Housings and wheels.
http://www.dieselbombers.com/5-9l-12v-p ... -tech.html
TheTowingCowboy
Postby cmann250 » Tue May 01, 2012 4:49 am
Tacoclaw wrote:With the new thread title change, I'm announcing that I've found a factory-style aftercooler and I'll be using it to run as my sole heat exchanger. After seeing all the boost leaks I'm not going to even bother trying to fix them all. My setup will now consist of a normal crossover going straight to the 'cooler.
With all the recent terminology changing, I'm more confused than usual :lol: Are you done with air to water all together and using air to air? Or are you using that industrial air to water?
Postby Tacoclaw » Tue May 01, 2012 5:52 am
Air to air is for quitters. :P
I'm getting a factory/industrial-style water after cooler and using my AC condensor setup to cool it. If I don't get rid of my shiny 'cooler I may look into using it between stages, using engine coolant, but that'll have to be one long winter to make me want to go through this again. :lol:
Postby TheTowingCowboy » Tue May 01, 2012 6:58 am
Tacoclaw wrote:Air to air is for quitters. :P
Or 1562 beers in he may get jolly and start!
TheTowingCowboy
Postby Tacoclaw » Tue May 01, 2012 7:21 am
Yeah, or that. Fine then, either a long winter or a short afternoon.
Shouldn't you be working?
Postby TheTowingCowboy » Tue May 01, 2012 9:03 am
Tacoclaw wrote:Yeah, or that. Fine then, either a long winter or a short afternoon.
Mondays and Tuesdays are my weekends :p I work Wed, Thur, Fri, Sat, and Sun.
EDIT: And here is a little segment from comp d about your D-Tech turbo
I have the D-Tech 62/65/12. It's a good street turbo, not much lag, good air, and a good wastegate setup. It has the standard s300 cartridge and they make their own housings. It's a sweet combo with the 5 x 12s, but the 5 x 14s may be a tad too much for it depending on where you set your plate.
And here is what you need to run for your atmosphere turbo
http://www.theboostlab.com/store/produc ... er%29.html
Last edited by TheTowingCowboy on Tue May 01, 2012 9:22 am, edited 1 time in total.
TheTowingCowboy
Postby Tacoclaw » Tue May 01, 2012 9:10 am
Every Monday off? No wonder you're such a happy guy. :P
I've sent out a few PMs to some turbo vendors about a different compressor housing. I'll let you all know when I know something.
Postby TheTowingCowboy » Tue May 01, 2012 9:25 am
Well I updated my previous post while you replied and yes thats why I am so dog gone happy =D And remember see if vannest has a second intake/cooler!!!! Lol I will remind you once you get off work also!!!!
TheTowingCowboy
Postby Tacoclaw » Tue May 01, 2012 10:01 am
Shit, I need to get the thing actually huffing before I worry about upgrades for it. :sad:
By the way, the drive you took last night was with the boost set at 30psi. I didn't think to crank it up for you. :oops:
Postby TheTowingCowboy » Tue May 01, 2012 10:22 am
Tacoclaw wrote:Shit, I need to get the thing actually huffing before I worry about upgrades for it. :sad:
I think it was 30 PSI cause it was peppier then other Cummins I have drove, but it wasnt what i was expecting with a Compound. So yeah need to crank her up.
TheTowingCowboy
Postby AHineman » Tue May 01, 2012 10:44 am
With Levi, nothing is like you'd expect. :lol:
Postby Tacoclaw » Tue May 01, 2012 10:50 am
I just leave it set at 30psi hoping whatever's wrong will fix itself. 30psi should be around the sweet spot for my 62, so that's where it stays.
One of these days I'll pull out and try to make a gap in traffic, my problem will *pop*, and all of a sudden I'm walking the truck sideways down the road in front of a bus full of college cheerleaders.
That's the plan, anyways. 8)
