Tacoclaw wrote:No kidding? Justin had a huh? of trouble with his IC'd fan being too high and his P-pump getting into the brake master cylinder. Between your post and the truck's Dana 60, I'm betting that was a gasser truck that was swapped over.
I'm running no shroud and electric fans, so I should be alright in that regard. One question since you're here, though. Since this is an 85 RC with the 727, will my transmission x-member line up or will it still be a hole back? I see people having to bump them back a hole, but they all seem to be going with OD transmissions.
Oh, and Head, this was the first RC I had ever seen that didn't have a red interior. I thought they all did.
Tacoclaw wrote:I'm not throwing it away, I'm selling it.
I don't mind getting rid of it all, this truck is really just a time sink for me and that setup has performed it's job beautifully. If I hadn't spent all that time fabbing and head-scratching, I would have been playing computer/Xbox or out drinking. Even if I ditch all the work I'd still keep the experience, and the pics.
PToombs wrote:Chatting with allegedly "hot" babes on the internet doesn't get you laid. Might better work on the truck and then go cruising for real babes.
