INJECTOR CHART
Postby KTA » Wed Dec 23, 2009 8:15 pm
Somebody send me a 190 injector and I will measure it and post the results. Then we will know for sure what is bigger and littler.
Postby PToombs » Thu Dec 24, 2009 12:24 pm
FYI, I got my info from Mark at PDR when I was looking for injectors.
Postby bgilbert » Thu Dec 24, 2009 1:53 pm
PToombs wrote:FYI, I got my info from Mark at PDR when I was looking for injectors.
Some will never learn :shock: :lol: :roll: !
Bill Gilbert
bgilbert
Postby PToombs » Fri Dec 25, 2009 9:52 am
:P
Postby PRINCETON_JAKE » Sat Jan 09, 2010 6:46 pm
I found a good deal on a set of used bosch 190 injectors for my 92 cummins. Am I reading this right that there smaller then stock? I also have a set of stock injectors from a 89 non innercooled, I can get them machined for free, would it be worth it? I would want to get them balanced and "cleaned" if i were to use them. Any idea how much it would cost and where to go? Any where in or close to minnesota?
Thanks, Jake.
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
Postby peobryant » Sun Jan 10, 2010 1:13 am
PRINCETON_JAKE wrote:I found a good deal on a set of used bosch 190 injectors for my 92 cummins. Am I reading this right that there smaller then stock? I also have a set of stock injectors from a 89 non innercooled, I can get them machined for free, would it be worth it? I would want to get them balanced and "cleaned" if i were to use them. Any idea how much it would cost and where to go? Any where in or close to minnesota?
Thanks, Jake.
Yes, the Bosch 190's are smaller than stock intercooled injectors, but they are much more efficient, so you'll get more power and better mileage from them. If you plan on towing, and don't want to have to worry about EGT's, these are the injectors to get, in my opinion.
I personally wouldn't run a set of Non I/C injectors in an intercooled truck, mainly due to money. By the time you got the Non I/C injectors machined and the pop pressures reset, you could more than likely buy a set of POD's (either new or used) which are bigger, for either near the same price, or cheaper.
What are your plans for the truck? We can't succesfully recommend an injector for you, without jnowing what it'll be doing. An injector for a high horse play toy won't work well in a truck that will always be hooked to a trailer.
Postby oldestof11 » Sun Jan 10, 2010 9:03 am
Also the NON IC injectors have a different spray angle.
Postby PRINCETON_JAKE » Sun Jan 10, 2010 9:27 am
Thanks for the reply guys. Its my daily driver, i haul mud trucks and fire wood with it, but right now the egts arnt an isue. Should I get the 190s? I could get the non innercooled injectors machined for free, I would just have to get them adjusted. Will the different spray pattern hurt much?
PRINCETON_JAKE
Postby peobryant » Mon Jan 11, 2010 6:37 am
PRINCETON_JAKE wrote:Thanks for the reply guys. Its my daily driver, i haul mud trucks and fire wood with it, but right now the egts arnt an isue. Should I get the 190s? I could get the non innercooled injectors machined for free, I would just have to get them adjusted. Will the different spray pattern hurt much?
No, the different spray angle isn't an issue at all (if you don't care about a little more smoke) but I still wouldn't put Non I/C injectors, in my truck. You plan on hauling, so I'd stick with the Bosch 190's and play with the pump as well. I'm not positive, but the 190's would probably net you better mileage as well, seeing as they are more efiicient.
Re: INJECTOR CHART
Postby Stomp » Fri Feb 12, 2010 9:36 am
Here is a little more info on the injectors that I have had built. I measured them whiel I was taking out my 370's and putting in the DDP's.
My honed 370's are 5x.013 (70lmp)Made 600+hp
DDP 4's are 5X.014 (72lpm) Made 600+hp
Honed 185's are 5x.010 ??? Never did dyno them. I sold them to a friend and then I was curious how they woud do if I had them honed so I bought them back. I Never did any testing with them. Maybe I will put my hot 12mm pump on and then see how they compare. They shuld make decent HP number, but I think the real gain would be in fuel milage.
Well I was actually shocked when I measured them. With all of the talk about 5x.016 and 5x.018 I thought mine would measure out to be around that size. Maybe I have some more HP to gain by stepping up to a bigger injector?
Stomp
93W250CTD,7 isspro gauges,Piers stage 2+ ported/polished/o-ringed head,ARP 12mm studs,ATS 3 piece,Custom twins by Brad @ Ponci's Diesel Center BTH3B/26 w/Piers HX40/16, custom 4"exhaust/ intake by Brad@ PDC,370's,KTA-Special 14mm Head/Rotor
Stomp
Re: INJECTOR CHART
Postby Fred S » Tue Feb 16, 2010 4:50 pm
So I see PDR is doing their own injectors for 1st gens. Anyone know anything about them?
92 W250 LB Crewcab 3" Alcans, NV5600 4x4, 35inch Toyo ATs, some tweaks
2001 Golf TDI TDTuning-Stg4, R520s, SBC, 17/22
94 Toyota Ex-Cab 4x4 (01 ALH(TDI)) TDTuning-Stg4, PP764s, SBC, 17/22
Fred S
Re: INJECTOR CHART
Postby djenkins6 » Sat Feb 20, 2010 5:16 pm
I found these on ebay, anyone know if they'll fit 89 1st Gen non-ic? ... and also any other specs about these. My truck has done 260,000km and is a bit smoky, had the injectors cleaned but think they need a rebuild or replace and these could be cheaper.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 1350wt_933
89 Dodge D250 2WD HX35 Turbo, BHAF, 81 Mercedes 300SD, 03 VW Golf
djenkins6
Re: INJECTOR CHART
Postby JBradley500 » Thu Feb 25, 2010 9:07 am
This is something I wanted to have. I believe it's all correct.
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500
Re: INJECTOR CHART
Postby blackfordd » Wed Mar 24, 2010 9:23 am
subscribed
[b]93 W250 LE Club Cab[/b]
A518, BD Torque Convertor, Banks Kit and Exhaust, 16 cm housing, 366, DennyT, Banks Pyro, Tach, Pyro and Boost Gauges, ASA intake, Super Duty transmission cooler, D70 3.54 LSD, Borgeson shaft
blackfordd
Re: INJECTOR CHART
Postby soggy » Wed Mar 24, 2010 9:38 am
cool :D
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
