Just a little more . . . . .
Postby Tacoclaw » Thu Nov 06, 2014 3:39 am
Well, at least you took care of the hard part first. :grin:
Postby Remps » Thu Nov 06, 2014 2:27 pm
Been reading lots of good things about the S478 li 6 blade. 40 grams lighter compressor wheel than a 80 mm compressor wheel, 5 grams lighter than a 71 wheel. Supposedly spools faster than a 75. I want one of these with a 92 turbine 1.1 T6 under my 35 with an external gate. I've also read that the 6 blade compressor spools a little slower under 10 psi due to more gap, and pressure loss, between the 6 blades compared to the 7 and 8 blades. Signature600 (Chris) over on comp d says he has a S478 6 blade with an 87 turbine T6 1.1 as a primary on a ve cummins and it worked (works) great. Some food for thought. :grin:
Postby RCCUMMINS89 » Thu Nov 06, 2014 2:40 pm
More info on this 478 please.... p/n? Link of someone carrying it? Link to where you read about it?
Postby Remps » Thu Nov 06, 2014 2:46 pm
I googled "s478 vs s480" today and read a few compd threads.
Postby Remps » Thu Nov 06, 2014 3:05 pm
Forced inductions carries them, I think they are 1200 with a 92 turbine.
Postby DMan1198 » Thu Nov 06, 2014 3:39 pm
Are they available with a 87mm turbine t4?
Postby Remps » Thu Nov 06, 2014 4:16 pm
It is, as are most of their S400 line up. Apparently they have different turbine wheels available as well. There is two or three versions of the 87, and I think two different versions of the 92 turbine. Kinda learning as I go along here lol. Lot of crap to look through sometimes to try and find tidbits of good info.
Postby DMan1198 » Thu Nov 06, 2014 4:41 pm
I think the j type is the one to get
Postby RCCUMMINS89 » Thu Nov 06, 2014 5:06 pm
Without a doubt... if one is going to go with an S400, go with the "high flow" or "j-cup" 87 wheel.
Postby oldestof11 » Thu Nov 06, 2014 5:28 pm
Everyone gets so worked up on "lighter, flows more, spools quicker" but never looks at maps and computes. They would rather throw money at it and pray it works as advertised.
Postby DMan1198 » Thu Nov 06, 2014 6:21 pm
I've had a lot of difficulty finding maps for bw turbos. I've got Garrett's site open all the time on my phone, and they've got all the maps right there (it's currently sitting on a gtx5533r)
Postby KTA » Thu Nov 06, 2014 9:34 pm
Most of the BW maps are readily available in the catalog. http://www.theboostlab.com/catalogs/BWT ... atalog.pdf
Postby DMan1198 » Thu Nov 06, 2014 10:18 pm
That helps quite a bit. Thank you. Turns out my s480 is about 15lb/min less than a gtx4508r (which is about the same size compressor wheel)
Postby BC847 » Sat Nov 08, 2014 10:40 am
Back when I first installed twins on my heap, I removed the oil pan to install the primary's oil return port. In putting it back together, clearly I had an issue with the gasket. Right there where the pan goes over the front of the crankshaft.
It's been a leaky/oily PITA since . . . .
Postby DMan1198 » Sat Nov 08, 2014 12:44 pm
A split in the gasket would do that. At least you're fixing it now
