1989 W350 want an intercooler
Re: 1989 W350 want an intercooler
Postby CumminsPower59 » Sat Jan 24, 2015 4:57 am
To elaborate a little more, I am happy with how the 370's perform. Burn really clean (depending on pump tuning), and will move some fuel when called for. I wanted to stay with Bosch for injectors. When I decide to go bigger, I'll get these honed out.
Postby 762frmafr » Wed Feb 04, 2015 10:43 am
Just got my 16cm exhaust housing installed from ptoombs. Just as everyone said, not a huge difference in power, although it is noticeable. With the 16cm housing, the turbo lights in 5th at 50-55 and pulls all the way to defuel vs. lighting at 60-65 and pulling. Definitely more drivable like this. On a side note, I made a 180 mile round trip the other day and used less than 1/4 tank of fuel which rough calculates to around 24 mpg. I don't think I want to mess with a fuel pin or springs just yet as I like that fuel economy. I will see what the exhaust housing does to economy if anything and go from there.
762frmafr
Postby PToombs » Wed Feb 04, 2015 6:13 pm
Glad it made a difference for you. I went from a 21 housing to that and it was real noticeable.
Postby 762frmafr » Wed Feb 04, 2015 6:21 pm
PToombs wrote:Glad it made a difference for you. I went from a 21 housing to that and it was real noticeable.
Did it make ahuge difference? No. But it made enough of a difference and moved the powerband down the rpm range far enough that now I don't feel the need that I have to get a 3200rpm spring.
762frmafr
Postby 762frmafr » Sun Feb 08, 2015 9:25 am
Adjusted the valves this morning to .08 and .18. Shows 86xxx miles on the ODO and the previous owner swears they are original. My guess is the valves have never been adjusted. I never thought a First Gen could run that smooth. Was definitely worth an hour of my time.
762frmafr
Postby CumminsPower59 » Mon Feb 09, 2015 3:39 am
A governor spring and a fuel pin will have little to no effect on your fuel economy.... Its your right foot that controls that.
Postby PToombs » Mon Feb 09, 2015 6:17 pm
762frmafr wrote:Adjusted the valves this morning to .08 and .18. Shows 86xxx miles on the ODO and the previous owner swears they are original. My guess is the valves have never been adjusted. I never thought a First Gen could run that smooth. Was definitely worth an hour of my time.
I did mine when I got the truck at 189k, I don't know the last time they had been done, but it was over 7 or 8 years. I only needed to adjust 2 or 3 of them. 8)
