cheap monster turned money pit ;)
Re: cheap monster turned money pit ;)
Postby Tacoclaw » Mon Sep 10, 2012 7:35 am
:cry: :cry:
It's been good to have you, man. Always liked seeing the results in this thread.
Postby tampabayBill » Mon Sep 10, 2012 9:34 am
Be sad to see you go, its been a good thread with lots of info.
Twins coming soon!
tampabayBill
Postby motorwood » Wed Sep 12, 2012 7:52 am
I'll keep posting till you guys tell me to take my p pump elsewhere :) and I'll list my 14mm VE, my KTA inspired fuel system, and my Budah Power injectors for sale once my ole school bus motor p pump is running.
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Postby motorwood » Mon Sep 17, 2012 12:37 pm
5th of 26 Friday night. Broke the spiders in the dana80 sat night.
motorwood
Postby motorwood » Fri Sep 21, 2012 8:02 am
Dynoed 618 1321
motorwood
Postby ellis93 » Fri Sep 21, 2012 9:34 am
that's still with the 14? :D
Postby Tacoclaw » Fri Sep 21, 2012 11:40 am
ellis93 wrote:that's still with the 14? :D
Probably not since he didn't mention anything that needs fixed and/or changed. :lol:
Postby ellis93 » Fri Sep 21, 2012 12:53 pm
motorwood wrote:Pulled the cam out, gear was working it's way off the cam messing with timing. Putting in a drop in cam and I guess I'll be leaving the VE brother hood :/
Was just wondering Taco, figured he'd might try one more time before PP-ville. So there :finger:
Postby motorwood » Sat Sep 22, 2012 2:10 pm
Yeah, that was with a P :/
motorwood
Postby motorwood » Sat Sep 22, 2012 2:29 pm
VE fuel system listed in for sale section
motorwood
Postby motorwood » Sat Nov 03, 2012 7:37 am
657 1211 kicked out the driveshaft, stuck the yoke in the wall, split the trans case and bell housing. Drove it home front wheel drive. AGAIN!
motorwood
Postby dazedandconfused » Sat Nov 03, 2012 10:02 am
I bet that scared the bejesus out of everyone. :shock:
Postby PToombs » Sat Nov 03, 2012 5:22 pm
Cool! :lol: Glad nobody get hurt on that adventure, great numbers too! 8)
Postby motorwood » Tue Nov 06, 2012 10:53 pm
I won't stand next to the passenger side of a dyno. 5th gear, 3.54's and 3800 rpm=132 mph when it let go!
motorwood
Postby motorwood » Tue Mar 25, 2014 11:44 am
Well, its been a while. Another combo, another dyno. 843hp 1060trq
motorwood
