1/4 mile et
Postby Begle1 » Sat Aug 04, 2007 7:15 pm
rbrettctd wrote:That cant be stock transmission. I ran the 727 for 4 years and never broke 83mph in it, not to mention I dont think the 3.07s would have the get up off the line for a low 13. Not saying I doubt him, but hes gotta be running the 518 or gear vendors.
The stock governor doesn't have much to do with the transmission's capablity. I can get up to 95 before my 3200 RPM spring hits the brick wall, and I think he said he was running a 4200 RPM spring... I'd be happy as a clam if I could get to that point in a quarter mile.
Postby KTA » Sat Aug 04, 2007 7:33 pm
It doesn't matter I am still the worlds fastest utility truck. :twisted:
Postby GLHS » Sat Aug 04, 2007 7:34 pm
Begle1 wrote:... I'd be happy as a clam if I could get to that point in a quarter mile.
RIGHT! That's what I said to myself three years ago. LOL
He could easily get the rpms out of it to turn that mph. Don't forget about tire size.
GLHS
Postby Begle1 » Sat Aug 04, 2007 9:25 pm
GLHS wrote:He could easily get the rpms out of it to turn that mph. Don't forget about tire size.
The question is whether or not he can do it fast enough, though...
Are you sure there aren't any gasser or common rail utility trucks out there, Brian? I'm sure somebody'd debate that you're the fastest...
Postby wannadiesel » Sun Aug 05, 2007 6:40 am
Uh, it is a 727 with 3.07's. The truck is wound up pretty good at the top end.
Best dyno: 408/844
wannadiesel
diesel guru
Postby KTA » Sun Aug 05, 2007 9:00 am
I have never run into any that were faster, and that is the way they announce me at St. Louis dragway, so they must not have seen any either.
Postby GLHS » Sun Aug 05, 2007 2:10 pm
KTA wrote:I have never run into any that were faster, and that is the way they announce me at St. Louis dragway, so they must not have seen any either.
LOL :lol: :lol:
I know I have'nt seen anything even close to Brians speed.
Let see here; Brians truck is heavier, a manual, runs on #2 only and still is way faster than all. IMPRESSIVE! :shock:
GLHS
Postby rbrettctd » Sun Aug 05, 2007 4:13 pm
Oh Ive noticed the top end power, believe me. I just never considered the 4200 spring.
Randy
rbrettctd
Postby Begle1 » Sun Aug 05, 2007 4:46 pm
GLHS wrote:Let see here; Brians truck is heavier, a manual, runs on #2 only and still is way faster than all. IMPRESSIVE! :shock:
You see, we can't do anything to steal his thunder on the mechanical, performance, speed, competition end of things... But the linguistic nit-picking arena hasn't been conquered by him yet!
Altough I haven't found any sub-13 second utility bed anything yet, so the claim holds up the fair bit of examination. And if somebody does have a utility truck that's faster, I will be willing to bet that it isn't 7500 lbs like Brian's is...
Postby rockjeep73 » Wed Jan 16, 2008 12:47 pm
Just for the non-believers...
8 1/2 minutes into the video...
ImageClick here to see Video
more info...
http://www.dieseltruckresource.com/dev/ ... hp?t=89844
2000 QCLB 2500 4x4, 12.05 @ 111
89 D-250, In The Graveyard
89 W-250, Mostly Stock
http://www.SHSDiesel.com
rockjeep73
Postby c12h26 » Wed Jan 16, 2008 1:12 pm
rockjeep73 what mods do you have done to run 13.34
1991 D250 reg. cab 518
4" turbo back,pump turned up,bumped timing,intercooler,HX52,366 spring,ground AFC lever,piston lift pump,Goerend converter,M/T ET street radials,nitrous,lowered.
c12h26
Postby flashgordon » Wed Jan 16, 2008 3:33 pm
too bad you broke out by .01 ............Ya goiter dieled in pretty good!!!!!!! ;)
Thank for sharing your video :thumright: :thumright:
Flash.
flashgordon
Postby rockjeep73 » Wed Jan 16, 2008 6:01 pm
c12h26 wrote:rockjeep73 what mods do you have done to run 13.34
hx35/40, POD's, ground fuel pin, pump maxed, ground afc foot, timing up 1/8", 4200 spring, water/meth, head is mildly ported with .020" thicker gasket, FASS, STOCK 3 speed and converter, hoosier DOT slicks, welded rear end.
I think thats everything.
rockjeep73
Postby cummins king » Wed Jan 16, 2008 6:09 pm
got a love those turbos wisling, nice run
93 4X4 auto
cummins king
Postby c12h26 » Wed Jan 16, 2008 7:04 pm
whats your 60' time ? what boost do you leave at ? have you ever checked the charge air temp ? ours was 589* at 35 psi,then we put an ice water intercooler on,air temp now 39*- 110* and cut 1/2 second off et !!
c12h26
