makin hps
makin hps
Postby flyinredneck » Thu Mar 24, 2011 2:02 pm
can any one give me some budget upgrades to reach 450 to 500 horses?
thanks
1992 w250 stock straight pipe with pump a lil tweaked denny t stage 2 fuel pin fuel screw at 3 turns
flyinredneck
Re: makin hps
Postby Richie O » Thu Mar 24, 2011 2:05 pm
You can't have a budget for 450 to 500. It will take several thousand bucks.
Re: makin hps
Postby flyinredneck » Thu Mar 24, 2011 2:14 pm
well yeah but i not looking for two much you know
flyinredneck
Re: makin hps
Postby delinquent » Thu Mar 24, 2011 6:26 pm
are you looking for 450-500 or are you looking for "not much." These are two completely different things. Budget will get you 250hp.
delinquent
Re: makin hps
Postby flyinredneck » Thu Mar 24, 2011 9:05 pm
well yeah im think injectors afc delete bhaf and if i get luck a turbo
what would get me the most bang for my buck
flyinredneck
Re: makin hps
Postby pulltilbroke » Thu Mar 24, 2011 9:35 pm
How much do you have to spend?? We will help point you in the right direction.
Re: makin hps
Postby flyinredneck » Thu Mar 24, 2011 9:50 pm
few grand i hust baught a denny t stage 2 pin and 3200 gov spring
any help i caan get would be great
flyinredneck
Re: makin hps
Postby flyinredneck » Thu Mar 24, 2011 9:52 pm
oh ans 4 inch dp ato 5 inch duals
flyinredneck
Re: makin hps
Postby pulltilbroke » Thu Mar 24, 2011 9:56 pm
First thing buy your self some guages, Is your truck an auto or stick? Fill out you Sig so we know what were working with.
After guages If you have an auto put a good converter in it. then after you get that done you can start doin the usuall performance stuff.
Re: makin hps
Postby flyinredneck » Thu Mar 24, 2011 9:58 pm
i have gauges coming 3 and 1 glowshift and then another fuel presure and tach
i dont know how to do the sig and its an auto
flyinredneck
Re: makin hps
Postby ciamcoop » Fri Mar 25, 2011 4:15 am
To fill out your sig go to "user control panel" then go to "profile" then "edit signature".
If you got a Denny T pin don't waste your time with the afc delete. You didn't mention anything about a 3200 rpm spring, get one of those and the dynamic timing spacer. Also advance your base timing, depending on how you use the pickup don't go too far or you'll lose some low end power. Concentrate on your supporting mods before you try making big power. You lots of airflow and a drivetrain that'll hold up, otherwise you're wasting your time and risking severe damage that'll need repair taking away from your go-fast fund. Set your trans up right and it'll net you more power at the wheels. Guys build a hot motor first and say I'll drive easy til I get a good drivetrain. They dont
'93 W250LE 4x4 club cab, getrag, denny t, 366 spring, 181/210 cam, bored. 020, KDP, 5x.014's, piston pump, 4" tbe, cold air, 255/85/16s, 3.54's one wheeler peeler
ciamcoop
Re: makin hps
Postby flyinredneck » Fri Mar 25, 2011 7:55 am
ok there ya go umm well how hard is the timing bumb to do? and transmission mods are soon to come
flyinredneck
