This was taken out of a 1997 Cummins from a 1 ton with an automatic.
The turbo was totally garbage, it did the "teeter-totter" thing when I checked it for play, it was horrible.
The seller told me he drained AT LEAST a gallon of oil from the intercooler.
My confusion is with the damage done to the piston.
Could the meltdown have been the result of the turbo pushing oil, or did an injector possibly lock up and drown the cylinder to melt down the piston so severely?
You can't see it directly, but the piston not only is melted down the side, but it's cracked from the top of the piston to the bottom of the skirt, as well.
Interestingly, the crank isn't even close to what one would expect from an engine that (appears to) have ran out of oil.
Sure, the crank was TIGHT (still turned, the engine WANTED to run!), but upon dis-assembly it wasn't even close to being scrap metal, likely a .010-.010 grind would clean it up easily.
It seemed more bound up by aluminum metal flakes from the piston, rather than actual main bearing damage.
Another interesting note is that the block is an extremely early '53' STORM block, which could be bored, except that it's likely to crack later.
The truck was built in Mid-July of 1997.
Glad it was cheap and had a P-7100 I can use or off.
