CPP 7 hole sac type sticks
Postby 92strokersmoker » Wed Apr 13, 2011 11:49 pm
Has anyone had good or bad feedback with these? I noticed they only sell 5s and 7s. Im more looking for a 6 hole but these kinda caught my eye. Whats the scoop?
92 w250 NV4500, Denny T stage II, HE351, 5x.012, FPS maxed, 3200 spring, 1/4" timing bump, ALL guages, Carter fuel pump. And some more
92strokersmoker
Re: CPP 7 hole sac type sticks
Postby ahale2772 » Thu Apr 14, 2011 5:26 am
I think places have had good luck with 7hole sac nozzles when on a ppump truck, with the higher injection pressures. I think even a 6hole sac nozzle is a bit inefficient on a ve, but then again if no one tries 7holers then we will never know how they truly do...
Postby 92strokersmoker » Thu Apr 14, 2011 6:58 am
very true point. I just wanted to see how they did on our trucks if it was worth a purchase. hopefully ill snag an answer
92strokersmoker
Postby chrislib » Thu Apr 14, 2011 5:33 pm
I`m loving mine so far, they replaced a set of pods. Power same or better, idle haze almost non existent except for when its cold, once it gets to temp it goes away, fuel mileage seems better but I don't track it on paper.
It`s not about how hard ya hit...it`s about how hard ya can GET hit and keep movin forward.
93 W250 CC 4x4, Auto,7x010`s, D-Zilla/16cm, 5in exh, BHAF/Smoky...don`t call it ratty, that`s patina son!
chrislib
Postby Smokem1 » Fri Apr 15, 2011 9:20 am
They are reboxed JL Machine injectors, Denso nozzle with 158° cone angle, straight answer no BS.
Smokem1
Postby chrislib » Fri Apr 15, 2011 5:09 pm
What he said, mine are 158`s which is`nt right but so far they are much cleaner and smoother than the pods were but then again pods are a compromise also. Like I said I`m happy with them but ultimately I`d like to have the correct angle tips.
chrislib
