Return line question
Postby Remps » Wed Apr 20, 2011 4:10 pm
How are you guys hooking up the return line with regulated lift pumps? Just tee into the factory return, or run a separate return line?
Re: Return line question
Postby cougar » Wed Apr 20, 2011 5:28 pm
Anything wrong with returning it to the inlet side of the pump?
01 2500 "the work truck".
cougar
Postby Richie O » Wed Apr 20, 2011 5:34 pm
I would use a dedicated return and go to the vent hose on the filler neck. I would not tap into anything thats already there.
Postby ahale2772 » Wed Apr 20, 2011 5:53 pm
not the greatest Idea to eliminate your return by feeding it into the inlet, return also acts as a air blead if the pump cavitates.
I made a bigger line coming from the regulator, and just T'ed the IP's return back in
Postby Remps » Wed Apr 20, 2011 7:24 pm
Ok, thanks guys. I will put a tee in the vent hose and return it there. Lift pump on the 93 took a dump, so I guess I will put the 7.3 fuel pump and 15 psi relief valve on the 93 tmo. Steve.
Postby Remps » Sun Apr 24, 2011 3:27 pm
Got the 7.3 fuel pump mounted and the relief valve teed into the vent hose a few days ago. Initially it was running 8-9 psi, and would suck it down to 0 by 15 lbs of boost. Adjusted the relief valve to 20 psi today, and now it'll hold 17 psi wide open. Smokes a little less at wot as well. I may turn the pressure down a little when the fuel filter gets replaced next week, as well as a section of 1/4" fuel line I had to use at the time. Will change it to 5/16", not much point in going bigger as the fuel pump fittings are 5/16". I'm sure bigger injectors will drop the pressure, at which point I will upgrade the draw straw and fuel pump inlet line and see how that goes. :) Oh, and I can't fuel the truck up with the fuel pump on anymore, just sprays back all over the place. :lol:
Postby ahale2772 » Sun Apr 24, 2011 4:53 pm
All the way out the filler neck? That's alot of returnin'
Postby Remps » Sun Apr 24, 2011 6:55 pm
60 gph at 0 psi, 30 gph at 70 psi is what I read somewhere..
Postby ahale2772 » Mon Apr 25, 2011 2:29 am
yeah i guess that would do it...
