cams cams cams
cams cams cams
Postby ford69557ci » Mon Aug 06, 2007 9:49 pm
i just pulled a 2000 24 valve with a busted block out of a bus. i was waonderin besides the lift pump lobe can i install this cam in my engine without a bunch of trouble?? and would it be worth any power over my stock 91 cam?? also what is the largest cam that can be ran without fly cuttin the pistons??
ford69557ci
Postby MikeThomas » Tue Aug 07, 2007 12:07 am
Hey man, do you have any pics of your rig? Sounds interesting?
1993 W250, 5SPD, ne370's, HTT STAGE IV/14wg, DennT Pin, BHAF, P-PUMP, PUMP TWEEKS, 4" EXHAUST, 366
MikeThomas
Postby KTA » Tue Aug 07, 2007 7:14 am
It should flow a little more than your stock cam, like 5% or so, but will no doubt loose a little torque. I have ton cams tons bigger that fit with no flycuts, it just depends on your valve timing events and your cam profiles as to how much cam you can fit.
Postby ford69557ci » Tue Aug 07, 2007 6:28 pm
i have some picks of the truck withe the old paint and old hx 35 setup but none of the new cuz its gettin painted right now. kta do you have any performance cams for sale? if so how much? if not where is the best place to get one??
ford69557ci
Postby KTA » Wed Aug 08, 2007 7:59 am
I do regrinds but you have to put in new lifters too, which is a bit of a pain. The cam is $500 exchanged for a good core. The set of tappets I think runs about $100, I would have to check an exact amount.
