400hp+
400hp+
Postby spencermumma » Tue Apr 26, 2011 6:54 pm
Hello i am wanting my truck to be in the 400 hp range i am wondering what size injectors i should run with a 64mm 71mm with a 14cm wastegate? I will be running a 518 transmission that is fully built. The head will be port and polished but wondering what are the best head studs ? also wondering if i should get a thicker head gasket and whether i should fire ring or oring the head?
thanks Spencer
1990 Dodge W250 5 inch stacks no muffler, Star wheel bottomed out, Smoke screw turned all the way, Fuel screw maxed, Denny T Fuel Pin, 2inch lift with 33x12.50 and alot more to come shooting for 450 horsepower any suggestions?
spencermumma
Re: 400hp+
Postby AHineman » Tue Apr 26, 2011 7:36 pm
I'd go with a set of 6x16s. (I wouldn't run anything bigger than 6x18s) I run a set from John Russin. Very little haze. When my VE fubared, I had them pop tested. All 6 within 2 bar of each other. I have a set of run of the mill ARPs in my truck with no problems. BC847 runs A1s with no problems. At 400 horse I don't think you need any of the higher dollar studs. The cheaper ARPs or A1s will do fine. Orings seem to be the way to go with street trucks. Fire rings don't like the heat cycles a driver sees. Head gasket is up to you. I run a .020 over marine gasket.
Re: 400hp+
Postby oldestof11 » Tue Apr 26, 2011 7:44 pm
You can pay for expensive head studs as insurance but the stock NEW headbolts are known to hold up in a 10 sec 2nd gen dually making well over 400hp.
Re: 400hp+
Postby spencermumma » Tue Apr 26, 2011 7:49 pm
would a 64/71 be able to cool 6x.16 ?
spencermumma
Re: 400hp+
Postby AHineman » Tue Apr 26, 2011 8:02 pm
spencermumma wrote:would a 64/71 be able to cool 6x.16 ?
For a street/play truck I would think you could keep egts in check with that turbo. Never ran one though. Ran those injectors with a stock turbo and my twins. Stock turbo = pegging pyro anytime you mashed the throttle. Twins = 1250* max. An intercooler would help a lot.
Re: 400hp+
Postby fatty » Tue Apr 26, 2011 10:22 pm
oldestof11 wrote:You can pay for expensive head studs as insurance but the stock NEW headbolts are known to hold up in a 10 sec 2nd gen dually making well over 400hp.
They also hold up in a 7 seven second tube chassis S10 with a Cummins...
Re: 400hp+
Postby spencermumma » Wed Apr 27, 2011 1:36 am
With this setup and wm inj do you think ill be over. 400 hp?
Thanks Spencer
spencermumma
Re: 400hp+
Postby ahale2772 » Wed Apr 27, 2011 3:24 am
I believe KTA made something like 480 with a combo like that ...(62/71 and large injectors)...dont quote me on that....
it may not be very drivable because of the size of the turbo, but you will make 400 if you can provide it with the fuel...
you will most likely not need the w/m to get it there, but it would aid in the drivability
twins would make it a usable 400....
Re: 400hp+
Postby spencermumma » Wed Apr 27, 2011 4:09 am
Someday i would like to have twins but i want a single first tho when you question drivability what do you mean by that?
spencermumma
Re: 400hp+
Postby The_Head » Wed Apr 27, 2011 5:04 am
He means the larger turbo might be laggy, and you would have a narrow powerband as a result. A 325 whp truck with a wide powerband might whoop up on a peaky 400 whp truck.
The_Head
Re: 400hp+
Postby KTA » Wed Apr 27, 2011 5:47 am
I did make 480+rwhp multiple times with a 62/71 S300. It was not cool at that level though as egt's would easily hit 1600+. It was never an issue driving, but I never towed with it.
Re: 400hp+
Postby spencermumma » Wed Apr 27, 2011 7:23 am
But with having an automatic shouldnt it help with the spooling issue?
thanks spencer
spencermumma
Re: 400hp+
Postby ahale2772 » Wed Apr 27, 2011 8:33 am
yes it will what auto are you running?
keep in mind that like many have said before, shoot for a quick spooling steup if you want power with the ve
if you are going to run a ported head...why not go with a cam at the same point? it would probably make that turbo light a bit faster and help the head really breath
Re: 400hp+
Postby spencermumma » Wed Apr 27, 2011 9:19 am
would like to run a 47rh that is build but if cant find one i will just build a 518 completely with bilit internals. what came would you recomend and who from?
thanks Spencer
spencermumma
Re: 400hp+
Postby ahale2772 » Wed Apr 27, 2011 9:53 am
hamilton cams makes a very nice cam
