Do-it-yourself straight piping on a 1st Gen
Postby Firstgenfanatic » Wed Aug 08, 2007 12:01 pm
I just went out and bought 3ft of 3" exhaust pipe and 2 clamps. Has anyone on here done their own straight pipe work? I'm just replacing the muffler section......thats it. Any suggestions or comments would be appreciated.
*1993 Dodge Ram W250 club cab*, mild performance built A518, Hughes Converter, turned-up VE w/timing bump, tow package, 16x7 Alcoa wheels, M&H "M5" fuel pin, 366 gov spring, 4" exhaust, 16cm turbine housing, cold air intake, Isspro pyro/trans/tach/boost, KDP secured
Firstgenfanatic
Postby PToombs » Wed Aug 08, 2007 4:57 pm
That's what I did on mine at first. I used 2 couplers (3"id x 3"id", welded them to the 3' pipe, then put the pipe in with the clamps. It sounded 8) .
:D
Learned my lession..........
Postby Firstgenfanatic » Wed Aug 08, 2007 11:08 pm
Well, no more in driveway exhaust fabbing for me. I tried to straight pipe my pickup tonight with clamps and hand-tools (don't have a welder). 3hrs later I have the muffler cut off, a pile of clamps and straps, and no way to secure it perminantly. :oops: After this, I'm never doing exhaust stuff on my own again. I can see it being easy if you have a welder........but clamps and hand tools is not gonna cut it. Time to fork out some cash and it get professionally done at the local muffler shop. :evil:
Firstgenfanatic
Straps?
Postby Ace » Wed Aug 08, 2007 11:31 pm
I thnik the "straps" part is probably where you went wrong. You need slip-fit couplers to mate the tubes. It can be done with the right sized couplers and clamps.
Ace
Postby Firstgenfanatic » Thu Aug 09, 2007 11:24 am
Happy to report that the exhaust work has been taken care of. It now sounds good. 8)
Firstgenfanatic
