by crewcab59 » Sun May 15, 2011 11:50 am
the pump will be mounted on the tank with a screen filter in front of it and gravity feed. as for the big filter, wouldn't the water trap not function properly if on its side?? if not then that would be good, ( unless there is just not that much water)the problem is getting all the air out of the system. if i could push through it then i could bleed it out with the pump............the reason for the gravity feed is at around 1/3 tank, hard braking or fast exceleration. the pump suckes air, runs out of fuel , then its time to bleed injectors.........this has to stop. the tank is a 41 gal. and flat. the draw staw is about 1/2" from bottom, I think thanks
1984 gmc crewcab s/b 6"lift with 92 cummins all on 37's gauges,intercooler,pump maxed, m&h#2, timing 1/4, 3200 spring, LBD 5x14,walbro fuel pump,getrag,big air intake/4"exhaust/stacks,, htt s300g 62/65/14,60lbs v/s,studs
