4" Downpipe?
4" Downpipe?
Postby ryanihf250 » Fri Aug 10, 2007 7:40 pm
What distributor has a just a 4" downpipe that they sell for a 92 Cummins? I can only find a 3" one. I am wanting to add stacks but I want a 4" downpipe.
Thanks
Ryan
Playtoy:1992 Dodge 350 4x4 SRW Cummins. 6in lift, 35in Pro Comp X , Dana 80 swap 4:10 Pump maxed, BHAF, 6x16inj, 3200 GSK, Piston Lift Pump, II SPS turbo.Street Pulling truck project. www.libertyantiquetractorpull.com
ryanihf250
Postby TWorline » Fri Aug 10, 2007 8:03 pm
You could try contacting these guys, they might sell just the downpipe http://www.dieselpro.net/product.html?pcfid=45 or Stans Exhaust http://www.stans-headers.com/diesel.htm scroll down their price list.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby 2muchtq » Fri Aug 10, 2007 8:20 pm
2muchtq
Postby rbrettctd » Sat Aug 11, 2007 11:02 am
I just built my own. Not too hard at all. 2 4" 90*s and a 3" flange, had one elbow and bought the other and the flange from airflo.com. With 2 elbows, flange, and a foot of pipe, itd run you bout $90 shipped probably (from airflo).
Randy
rbrettctd
Postby Philip » Sat Aug 11, 2007 12:08 pm
rbrettctd if you look at his sig he has a W series. It is a lot harder to fab your own system on them.
With the 4" downpipe you better get the next two pipes to go with it. The area around the transfer case will be hard to mfg the pipe without a bender. A stan's 4" system has a couple of bends that come in around a 30 degree bends.
I have most of a stans 4" on my dually.
Postby rbrettctd » Sat Aug 11, 2007 2:48 pm
I just meant the down pipe. I bought a system for mine several years ago and just built the dp. My pipe has the drop for the transfer case, I had it swapped for straight pipe to regain clearance. With about $200 or so in elbows and pipe, and the flange, one could make the 4" dp and get the exhaust around the transfer case and to the stacks.
Or fab your own dp and a muffler shop (the one I deal with could anyway) could get you to the bed for about $100. I had 5' of pipe put in and only cost me $50.
Randy
rbrettctd
