boost install
boost install
Postby swampthang » Tue Aug 21, 2007 9:55 pm
ok guys i got a question for ya i have a non intercooled cummins 91.5 and i need to install my boost guage i read on here in a link that you have to drill and tap a hole to get a boost read now on the intercooled trucks like my 93 i just pulled the lil plug right behind the fuel lines behind the bracket and hooked it up there this non intercooled truck has the same plug why can i not use it on the non ic truck i dont see any reason
JC
Bloody Knuckle LLC
Transport,custom fabrication and used parts.
Based out of Halltown Mo 65664
JC
bloodyknucklellc@gmail.com
swampthang
Postby bgilbert » Tue Aug 21, 2007 10:53 pm
You just drill a hole in the throttle bracket big enough to get your socket over the brass fittings for the boost tubing hook up. You are right, the 1/8npt tapped plug is in the same place be it intercooled or non-intercooled motor.
Bill Gilbert
bgilbert
Postby swampthang » Tue Aug 21, 2007 11:11 pm
cool thanks i guess will ad that to my list tomarow too lol
JC
Bloody Knuckle LLC
JC
swampthang
Postby swampthang » Thu Aug 23, 2007 7:02 pm
umm ok well i installed the guage today on the lil port on the side of the intake only prob is no boost showing on the guage checked the line no kinks ?? i un did the line from the guage and there is no air blowing threw it when the engine is running shouldent there be ?? any ideas it is new lines new nuts new farrels same guage i used before
JC
Bloody Knuckle LLC
JC
swampthang
Postby 90firstgen » Thu Aug 23, 2007 8:52 pm
Sounds like the ferrel pinched the line shut.
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby swampthang » Thu Aug 23, 2007 9:27 pm
it did the first time went on sideways but i redid it i guess i will have to check it again on the motor side ??
JC
Bloody Knuckle LLC
JC
swampthang
Postby 90firstgen » Fri Aug 24, 2007 5:03 am
swampthang wrote:guess i will have to check it again on the motor side ??
JC
Yes sir. Make sure and cut off the parts that have been pinched too.
3200 Spring
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
Stan's 4"
90firstgen
Postby Cschafer » Tue Aug 28, 2007 12:24 pm
You shouldnt be able to feel any air coming out of the hole, I'm assuming that if your hand was on it you wernt driving it, the truck won't make any boost unless you driving it. If it's stock it wont make much boost untill you floor it up a hill. :cry:
91 w250 wrecker
Cschafer
Postby swampthang » Tue Aug 28, 2007 5:49 pm
ya i got it working it pegs my 30 psi guage on a hard pull :) runs about 15-20 crusing down the interstate now i just have to get a new pyro probe for my temp guage any ideas where to get one ??? i have the isspro guages
JC
Bloody Knuckle LLC
JC
swampthang
Postby 90firstgen » Tue Aug 28, 2007 8:53 pm
15-20 is pretty dern high. Make sure your wheels aren't locked up :o
3200 Spring
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
Stan's 4"
90firstgen
Pyro probe
Postby SChandler » Wed Aug 29, 2007 12:41 pm
If you need a replacement probe for an Isspro gauge, you can order one from Isspro directly (as you can with any of there gauges and accessories) at http://www.isspro.com. You can also order the replacement probe from pretty much any place that sells Isspro gauges.
SChandler
Postby swampthang » Wed Aug 29, 2007 3:43 pm
lol ya i was suprised running about 70 75 down the interstate just crusing not pulling a hill or anything 15-20 psi constant put a load on the engine and we peg the 30 psi guage :) makes me happy now i just got to get an ic in it to cool it down lol
you need a replacement probe for an Isspro gauge, you can order one from Isspro directly (as you can with any of there gauges and accessories) at www.isspro.com. You can also order the replacement probe from pretty much any place that sells Isspro gauges.
thanks i will look into it
JC
Bloody Knuckle LLC
JC
swampthang
Postby dpuckett » Wed Aug 29, 2007 5:30 pm
How fast were you going, and what gears do you have? Going 80-85 with 4.10s will get you 15-20psi at crusie.
Be sure to put the probe in the manifold. It is easy to drill and tap. Just need a little grease. The manifold is soft enough I use Vice Grips on the tap, and have had no problems.
DP
Postby swampthang » Wed Aug 29, 2007 6:14 pm
doing 70-75 i have 3.54 and i am running 285-75-16 bfg mud terrains spining about 2k on the tach
as for the pyro prob the old one i have mounted in the down pipe with a clamp ?? what is wrong with that style mount ?
JC
Bloody Knuckle LLC
JC
swampthang
Postby SChandler » Wed Aug 29, 2007 6:30 pm
With the temp probe in the manifold, you get better (more accurate) temp readings. By the time the exhaust reaches the downpipe, it has gone through the exhaust manifold, turbine housing, and started down the downpipe, shedding heat the whole way, leaving the temp reading at the downpipe more inconsistent than the reading at the manifold. At idle or other low load situations the difference between manifold and downpipe measurements might be 100* (with the lower temp being read at the downpipe). But under full throttle banzai runs, the temp difference has been shown to be between 300-500*(from magazine results and other parties curious enough to run two pyrometers). Thus, the measurement of 800-900* at the downpipe could be a piston-melting 1400* at the manifold (and even higher in the cylinder) or it might only be 1200* at the manifold, which you can run all day long (according to various sources who quote Cummins literature).
SChandler
