remote fuel system
remote fuel system
Postby 91bluecummins » Thu Aug 11, 2011 10:42 am
what is a remote fuel system is it like a airdog or a fass i cant find any thing on it and is there any fueling upgrades i could do to were it will push a little more fuel up top without messing with the VE ,like where i could get more fuel when i needed it at a flip of a switch get more pressure
thanks
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: remote fuel system
Postby Remps » Thu Aug 11, 2011 2:35 pm
I guess an airdog or fass could be considered a remote fuel system. As long as you have at least 8 psi at the inlet, no matter which lift pump you use, it will be sufficent for a 12 mm VE. More than 20 psi and you're playin chance with your front seal. Some put their KSB on a switch to increase internal pressure and get more power.
Postby 91bluecummins » Thu Aug 11, 2011 4:15 pm
thanks i saw this and i was wandering what it is
http://www.youtube.com/watch?v=XyILfAhJJdY
91bluecummins
Users browsing this forum: No registered users and 75 guests
