Looking into raptor fuel pump HELP!
Postby Tsbourne09 » Wed Aug 17, 2011 2:16 am
I am conaidering buying a raptor fuel pump. What are the gains of this pump and is it worth it? My pump is maxed and it seems like it may begin to run short of fuel at high rpms. Is it worth buying?
Not On Yet: 60#VS
Tsbourne09
Re: Looking into raptor fuel pump HELP!
Postby Tsbourne09 » Wed Aug 17, 2011 2:32 am
Also where and how do i install a fuel pressure guage on this truck (93)
Not On Yet: 60#VS
Tsbourne09
Postby Hansen01 » Wed Aug 17, 2011 5:17 am
ebay has them, and yes, the originals wont keep up with a maxed pump
Under construction...
Hansen01
Postby 91bluecummins » Wed Aug 17, 2011 9:49 am
is it really worth it and do u run it threw the original fuel filter and just block off the original lift pump
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Postby Tsbourne09 » Wed Aug 17, 2011 12:18 pm
what should the fuel pressure be set at and how do i hook up a fuel pressure guage? more specs?
Not On Yet: 60#VS
Tsbourne09
Postby Hansen01 » Wed Aug 17, 2011 3:51 pm
i know it is worth it if you have a tuned pump, cause it isnt good at all to run an injection pump lean, as for the other question, i have not installed one on mine either yet :? waiting for the funds,lol
Hansen01
Postby Tsbourne09 » Mon Aug 22, 2011 12:36 am
Where the cheapeat place to buy the raptor system at?
Not On Yet: 60#VS
Tsbourne09
Postby Hansen01 » Mon Aug 22, 2011 3:49 pm
ebay has a good price, as for the fuel pressure i was gonna set mine about 10 and make sure it didnt drop to 0
Hansen01
Postby Tsbourne09 » Fri Aug 26, 2011 11:07 pm
should i be getting the 100gph or the 150 gph and what should i set my fuel pressure at?
Not On Yet: 60#VS
Tsbourne09
Postby Hansen01 » Sat Aug 27, 2011 5:28 am
go big or go home, theres not much of a price difference on em, about 10psi of fuel pressure, my dad runs 13 and it hasnt blown any seals out yet
Hansen01
Postby 91bluecummins » Mon Aug 29, 2011 9:16 am
thats 10psi at idel or at wot
91bluecummins
Postby Hansen01 » Mon Aug 29, 2011 6:37 pm
idle, his had a holly blue or something on it and i couldnt ever get it down to zero, and his is full power screw is in all the way, and the raptor should flow more anyways
Hansen01
Postby collegekid » Sun Sep 11, 2011 6:39 am
Ive got the 2nd gen help on mine and it idles at 15psi and at WOT hits 17psi, can't pull it down....rebuilt the injection pump, no seals have blown yet. its a little more expensive, but you never have to worry about the pump quitting bc of an electrical problem
collegekid
Postby 91bluecummins » Sun Sep 11, 2011 1:00 pm
i ordered a raptor off ebay and whats a good fuel filter
91bluecummins
Postby Tsbourne09 » Sun Sep 11, 2011 5:07 pm
Same! Got it for $375 shipped! Same question! Also what is a valet switch?
Not On Yet: 60#VS
Tsbourne09
Users browsing this forum: No registered users and 107 guests
