5 x .014 sdx injectors
Postby Phatstack » Sun Aug 21, 2011 9:29 am
I have a set of 5 x .014 sdx p-pump injectors, do I only have change the pop off pressure to to make them functional in my non ic truck? If so what would that pressure be?
01 duramax service truck (up for trade for a ve powered truck), yard full of cummins 12v projects
Phatstack
Re: 5 x .014 sdx injectors
Postby dazedandconfused » Sun Aug 21, 2011 9:40 am
No the lines that feed the injectors are different and since the non intercooled are 9mm the nozzles can't be swapped either. That is if you are still running a ve.
Postby dpuckett » Mon Sep 05, 2011 9:20 pm
You CAN have the tips swapped over to your VE injector bodies, though, and run them with the top hat injector adaptor washers if you still have the 9mm head.
DP
Users browsing this forum: No registered users and 66 guests
