some suggestions
some suggestions
Postby christopherctd » Thu Sep 08, 2011 7:52 pm
i need some suggestions. I have a 1992 2wd reg cab cummins auto trans just redone wit new torque converter. As far as mods i have a cat borgwarner s300 with 4in down pipe to 5in exhaust. i am looking to do injectors i do not tow just a dd. also i will be doing 366 spring, pump adjustment and fuel pin ground. im not sure what size the cat is a believe 62 inducer? smog doesnt bother me i live in the middle of no where anyways. so any suggestion on injector would be appreciated? thanks
92 reg cab 2wd fresh 518, s300, 4in exhaust to 6 in stack, 5x016 sticks, modded pump
christopherctd
Re: some suggestions
Postby oldestof11 » Sat Sep 17, 2011 5:55 pm
What's your overall HP goal?
Before anything else, I would drop the trans pan, tighten the apply bands up, and up the line pressure. Then you can also adjust another screw to change shift points slightly to make use of the 366 spring. That is if you haven't done so already.
5x12,5x14,6x16s are gonna get you HP and a smoky beast but will give a good hit.
I just bought a 63ish mm turbo. Gonna rebuild it and put it on with some 5x14's or whatever else I can pick up cheap. :lol:
Users browsing this forum: No registered users and 76 guests
