pics please of fuel system
Postby 91bluecummins » Mon Sep 26, 2011 7:08 am
i need to see how yall put your fuel system with a fuel filter on our truck underneath your frame. i like how 1stgenfarmboy put his may i see how every body else does it cause im leaning on putting it on the out side of the frame where it starts to s
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: pics please of fuel system
Postby Marty Z » Mon Sep 26, 2011 8:34 pm
This is how I mounted filter pump and fuel on off valve.
1991 350 4X4 5 Speed he351vgt with brake 5.12 sdx injectors 60#springs 4" exhast 366 spring pump mods Holley fuel pump Gages 190000 miles
Marty Z
Postby 91bluecummins » Tue Sep 27, 2011 11:11 am
THANKS WHATS THE ON OF VALVE FOR
91bluecummins
Postby dazedandconfused » Tue Sep 27, 2011 11:55 am
My guess is it's setup like a tractor so when you change the filter you close thevalve to keep it from dumping fuel.
Postby 91bluecummins » Tue Sep 27, 2011 6:14 pm
thats pretty smart
91bluecummins
