MO POWER
MO POWER
Postby 04Fummins » Tue Sep 27, 2011 10:38 pm
Ok guys (and gals), ive come to a cross roads with my Fummins conversion. I've been driving it for about 2 years now, played with the pump a bit, have an intake and 5" exhaust. I'm goin back in to fix a few things so I figured I might as well see what I can do to get it close to the 300 hp range. I've already picked up an he351cw, new manifold, and some gauges. What injectors and fuel pin would be best suited for play and daily driving?
04Fummins
Re: MO POWER
Postby 04Fummins » Tue Sep 27, 2011 10:40 pm
Also forgot to add that this is an intercoled VE motor out of a 93'
04Fummins
Re: MO POWER
Postby crewcab59 » Wed Sep 28, 2011 8:56 am
I like my LBD 5x14's and M&H fuel pin, with out pulling something, I can run the crap out of it and not worry about egt's. have to use your in town-manners though because it will black out the road, if i want to. :(
Injectors, LBD or SDX they are cheaper price and work good.
fuel pin, M&H or Denny-t would be my choice, I believe the Denny-t is like the M&H-5 all five of the m&h pins are the same at WOT, the only difference is WHEN they max fuel.
1984 gmc crewcab s/b 6"lift with 92 cummins all on 37's gauges,intercooler,pump maxed, m&h#2, timing 1/4, 3200 spring, LBD 5x14,walbro fuel pump,getrag,big air intake/4"exhaust/stacks,, htt s300g 62/65/14,60lbs v/s,studs
crewcab59
Re: MO POWER
Postby Tacoclaw » Wed Sep 28, 2011 9:55 am
Assuming you've got an intercooler of some sort, just a set of 5x14s and a 62mm S300 should give you a nice, safe cushion for 300hp.
Can you hit 300 on a stock turbo? Maybe, but it'll probably be toasty and I wouldn't expect it to be worth much with a trailer. :sad:
Re: MO POWER
Postby 04Fummins » Wed Sep 28, 2011 4:54 pm
Leaning strongly towards some POD's and a new fuel pin at the moment. I think that with some pump timing and my new he351 w/ 5" exhaust should make some decent power.
04Fummins
Re: MO POWER
Postby dazedandconfused » Wed Sep 28, 2011 5:19 pm
There are allot better injectors for the money then pods. Check out New Era or SDX just to name a couple.
Re: MO POWER
Postby crewcab59 » Thu Sep 29, 2011 6:59 pm
04fummins what trany did you use, if it is the dodge 727, or the a518 you should upgrade the torque converter, (don't know
what ford has) just thinking, if it is a manual it won't take much to get to 300hp.
crewcab59
Re: MO POWER
Postby 04Fummins » Sun Oct 02, 2011 8:06 am
crewcab59 wrote:04fummins what trany did you use, if it is the dodge 727, or the a518 you should upgrade the torque converter, (don't know
I'm using a zf6, got my he351 test fit yesterday too.
04Fummins
Re: MO POWER
Postby oldestof11 » Sun Oct 02, 2011 10:41 am
Stock fuel pin ground on the deep side is the best for the money. Then you turn it around to the shallow side for economy.
The ZF6???? How do you like it?
Re: MO POWER
Postby 04Fummins » Mon Oct 03, 2011 11:46 am
oldestof11 wrote:Stock fuel pin ground on the deep side is the best for the money. Then you turn it around to the shallow side for economy.
It's a Ford 6spd many, love it.
04Fummins
Re: MO POWER
Postby oldestof11 » Mon Oct 03, 2011 1:13 pm
I have been seriously contemplating putting one in my truck in the future... What adapter plate did you use?
Re: MO POWER
Postby 04Fummins » Tue Oct 04, 2011 10:12 am
Fordcummins.com adapter. Word to the wise, go with a destroked adapter. Much better quality, the only reason I used the fordcummins was because it came with the trans. Ordered a bunch of 3" SS intercooler piping last night to plumb in my he351cw. Can't wait
04Fummins
Users browsing this forum: No registered users and 74 guests
