Bosch Ve 3800 gov spring
Postby Tsbourne09 » Tue Oct 11, 2011 4:05 pm
I ordered the 3800 gov spring. do i NEED 60lb valve springs?
I got the gov spring here http://www.tndieselpower.com/site/produ ... ov-spring/
Not On Yet: 60#VS
Tsbourne09
Re: Bosch Ve 3800 gov spring
Postby elm302 » Tue Oct 11, 2011 5:26 pm
I believe so I'm gonna put my 60s in and get that spring.
93 W250 Getrag Valair clutch HIDS 3200 spring Denny 2 pin M&H spacer Airdog 150 5x16s 63/68/.91 4" duals Isspro gauges BHAF 2nd gen intake water meth 60# springs 3 piece manifold. Next up PS intercooler
elm302
Postby oldestof11 » Tue Oct 11, 2011 5:43 pm
No, as long as you don't take it that high.
I just installed the 4200 RPM spring. The B*TCH is HARD to shorten. Took me an hour then Andrew (pulltilbroke) came over and did it in 5 mins. :roll:
I did enjoy the new found R's...
Postby elm302 » Tue Oct 11, 2011 5:55 pm
Here's a dumb question for yall ok if the ve stops fueling pretty much around 3000 what is the purpose of goin to a higher spring. I'm just curious.
elm302
Postby Tacoclaw » Tue Oct 11, 2011 5:55 pm
oldestof11 wrote:No, as long as you don't take it that high.
That is a pretty shaky requirement. ;)
I know I never expected to tach mine out with a 3200 spring, considering I never really did it before, but I know I always end up on the governor now that I've got some more power to play with.
Postby Tsbourne09 » Tue Oct 11, 2011 7:20 pm
Thanks. So like anything as long as you dont drive it like a teenage boy its fine. Im getting dennys pump top so im doing it then. Wouldnt stiffer valve springs be hard on the motor on the low end and start up?
Not On Yet: 60#VS
Tsbourne09
Postby oldestof11 » Tue Oct 11, 2011 7:20 pm
My power stops around 2800-3100 rpms according to the SOTP dyno. I think my lift pump is not keeping up.
I have for when I am going to be pulling/drag racing. I don't want the power stopping at 3000 so it can defuel. We will see if the idea works.
Postby Tacoclaw » Tue Oct 11, 2011 7:26 pm
I don't have a tach, but my truck pulls right up to an obvious de-fueling point that is higher than it was before the 366. You could feel it slowly de-fuel before, where it now pulls right to it and de-fuels really quickly.
Stock lines with a LPLP.
Postby jacobwebb57 » Tue Dec 27, 2011 7:32 pm
hi thi si sa little off topic but i just put the 3800 gov springs in my 91.5 put it all back to gether the way it was, it took a while but finaly got it started. as soon as i let of the throtle it shuts off, and if i rev it it only lets me get to about 1200 rpm....idle screws are exactly where they were..full fule screw is in one turn now, it was out one turn and at teh stock position it did teh same thing every time...also when i look down into teh hole where the fuel pin goes i cant see the little pin that it rides on idk if it is how it was ment to be i have never looked at if befor?..any info would be helpfull... my truck is sitting in my shop at work and my boss is gonna be mad so i need to get it going...please help!!!!
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Postby AHineman » Tue Dec 27, 2011 7:45 pm
http://1stgen.org/viewtopic.php?f=1&t=3229
Sounds like you need to reindex your throttle.
Postby The_Head » Tue Dec 27, 2011 8:18 pm
I got one coming as well. Now, finding the motivation to install it... that's another story.
The_Head
Postby rattlebox93 » Fri Dec 30, 2011 11:05 pm
Dont even screw around with anything but the 4200 (354) spring that sping singlehandedly makes my truck and animal
rattlebox93
Postby The_Head » Sat Dec 31, 2011 8:09 am
rattlebox93 wrote:Dont even screw around with anything but the 4200 (354) spring that sping singlehandedly makes my truck and animal
Please post a dyno sheet to show us what an "animal" your truck really is.
EDIT: Based on what you have listed in your sig, it probably does run pretty darn good.
The_Head
Postby shiftycapone » Sun Jan 01, 2012 7:43 pm
I'm really enjoying mine :mrgreen:
1990 D250
shiftycapone
