Screaming Eagle 63/68/14
Postby Ram360man » Wed Oct 12, 2011 11:05 pm
Got my new turbo installed finally on sunday. Been taking it easy so far due to lack of head studs but impressed none the less. In DD situations it runs slightly hotter accelerating but runs the same at cruising as my old hybrid H1C. Maybe 50 degrees hotter accelerating if even that. From a dead stop flooring it doesn't lag to bad for how big it is. I think a lot of it is my pump needs tuning and my timing being to the head. Tight TC doesn't help much either I guess. I hit 10 psi around 15mph and 20psi around 20mph. At 25 i'm fully spooled. Probably 25 percent slower spool then the hybrid. H1C ran around 38 lbs and 1700 degrees. Now runs 45 lbs with wastegate disconnected and could only get it up to 1300 on a 0-80 blast. top end is way cooler due to better exhaust flow. Exhaust note is even lower pitched now also. Just running the downpipe. Major drone. :roll: Hopefully get my head studs and new injectors in this weekend and tune it better. Not sure how its going to like towing but so far i likey. Best part of it is that the seals aren't shot so i don't have to smell that stinky oil burning all day now.
1989 W250. Maxed fuel pump. 5x14. 63/68/14. PS Intercooler. 4200 gov spring. 188/220 cam. Built 727
1989 W250 60mm gds. 2.5 inch crossover. turned up pump. Stock 727.
Ram360man
Re: Screaming Eagle 63/68/14
Postby ahale2772 » Thu Oct 13, 2011 4:29 am
cool! that is a very appealing turbo setup IMO every one i have herd says it spools like a 12 and pushes air like a 64. p-pumpers dont seem to like them but its about time a few ve-ers tried them.
where did you buy from?
Postby Ram360man » Thu Oct 13, 2011 9:19 am
Diesel Auto Power. Got a set of 5x.014 injectors from them too that just showed up this morning.
Ram360man
Postby sshort » Fri Oct 14, 2011 3:37 pm
I run a ED 63-68-12 and it spools very good with my set up It takes some time to get the tune right but when you get it you will no
1991 D350 ddpstg3 injectors pump mods trans mods 63-68-12 turbo water/meth & nitrous
sshort
Postby Ram360man » Fri Oct 14, 2011 10:36 pm
Well thats good to hear. Just got done working for the week so hopefully get the studs in and the pump tuned better now.
Ram360man
Users browsing this forum: No registered users and 77 guests
