oil return w/twins
oil return w/twins
Postby NYCEGUY01 » Tue Sep 04, 2007 10:29 am
What are you guys allready running twins doing for the 2nd oil return.
Are you just teeing them together. I would like to avoid adding a drain into the pan if at all possible. I dont want to drill into the pan with it still attached and dont want to pull the motor to remove the pan for a proper install.
NYCEGUY01
Postby Begle1 » Tue Sep 04, 2007 12:27 pm
I think that there's actually a second oil supply port available, right next to the one that feeds the stock turbo.
Ohhh, you're asking about the return...
In that case, I was told this back a couple years ago when I asked the same question, but I've since forgotten.
Postby Fnschlaud4620 » Tue Sep 04, 2007 5:47 pm
When I did mine I cleaned the area on the oil pan with a DA and 80 grit about the size of my hand. Then I used a sharp punch (on Air Hammer) to puncture a hole in the pan like a bullet does, it tears the metal and no shaving go into the oil pan at all. Then I keep using a larger object to open the hole to the size I need it, and some help from a sharp chisel.
Then I weld washer on the end of the piece of tube I will be putting into the hole so it is slightly on an angle and there is about 1/2" sticking into the oil pan
then stick it in the hole and weld the outside of the washer to the oil pan.
I caution you make sure that you put the return in between two oil pan bolts so you still can remove the pan, and there is a baffel in there, if mine would have been 1 more pan bolt foward I would have missed it completly
See picture. It is not a good picture but it may help.
Fnschlaud4620
Postby NYCEGUY01 » Tue Sep 04, 2007 6:17 pm
I was going to try and avoid the oil pan route if at all possible.
Are there any other good options ??
On a couple of import turbo jobs I did we just took a blunt chisel for the air hammer and ground it to a point then pushed it through the pan. After that I just used a tap and threaded the hole for the correct fitting. I greased the tap up good and caught most if not all the debris. That seemed to work well but I still didnt feel real good about it.
NYCEGUY01
Postby Fnschlaud4620 » Tue Sep 04, 2007 6:45 pm
the only other option I can think of is a small oil tank under the turbo and an electric pump pushing oil back into the valve cover
Fnschlaud4620
Postby KTA » Tue Sep 04, 2007 8:31 pm
Mine is t-d back into the stock return but my twin setup is unigue and I have my Loe pressure turbo mounted higher and further forward than any other setup I have seen. As long as your turbo drain will gravity feed out into the pan you are fine.
Postby NYCEGUY01 » Tue Sep 04, 2007 9:49 pm
I think Ill probably t it in with the other one first. I have used the small pumps on sleds that I turbo'd and they worked well but its just one more thing to go wrong. lol
If it doesnt work Ill just punch the hole in the pan. I still havent figured out the big turbo placement yet but have been leaning towards leaving the current one as-is and mounting the new one fairly low.
I have lots of room on the chevy. If I go that route the pan will be my only option as it will be too low for the current drain.
Once I actually get in there and start the fab work the room available etc.. will probably make up my mind for me.
Thanks for the replys.
NYCEGUY01
T
Postby seeker1056 » Fri Sep 07, 2007 10:03 am
a one inch "T" works just fine for the two turbos - there isnt that big a volume of oil to stack a 1" line full.
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby PToombs » Fri Sep 07, 2007 4:44 pm
Ever start your truck with the turbo oil line off? :shock:
dont have to
Postby seeker1056 » Sat Sep 08, 2007 8:18 am
i have a reinforced clear line on it - ;o)
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Rebel Ram » Sat Sep 08, 2007 8:51 am
Umm,, Yeah!
www.turbodieselregister.com/forums/shop ... -done.html
BTW, Isn't that starter on the wrong side? What is that app?
"Big Ugly"-93 3/4 T extra cab 4X4 5 speed
"Big Hips"-92 1 Ton reg cab 4X2 Auto
"The ohwun"-2001 3/4 T quad cab 4X4 auto
Rebel Ram
