Nitrous Questions???
Postby ryanihf250 » Tue Sep 04, 2007 6:44 pm
I am taking the NOS Nitrous kit off of my 7.3 Powerstroke and putting it on the Cummins. I have a few questions about it.
I was wondering how far away from the intake you put the Nozzle that jets?
Would you need to adjust the timing when you add nitrous if so what degrees? I know on the Powerstroke I had the chip reburned to adjust the timing for the nitrous.
Hoping to add some quick horsepower before the next pull!
Thanks
Ryan
Playtoy:1992 Dodge 350 4x4 SRW Cummins. 6in lift, 35in Pro Comp X , Dana 80 swap 4:10 Pump maxed, BHAF, 6x16inj, 3200 GSK, Piston Lift Pump, II SPS turbo.Street Pulling truck project. www.libertyantiquetractorpull.com
ryanihf250
Postby boostedve » Wed Sep 05, 2007 6:53 am
from what i have been told and have read the timing doesnt need to be changed like a gas engine. and for the nozzle not sure about that i think everyone has there own spot for that some say here some will tell you there. but i dont see that you have any gauges so if your gonna put some nos on her you better get you some gauges so you can watch that egt and the boost. and make sure you start off with a little jet and then get bigger so you dont dryring..
good luck
FOR SALE 1991 dodge d350 hx40 2nd gen intercooler, few pump mods, 366 spring, no afc, timing bump,pistion lift pump, 5" down pipe, bhaf, old smokey fuel pin, boost, pyro, tach gauges 14.10 @96mph 310hp, pm for pics and info..
boostedve
Postby ford69557ci » Sun Sep 09, 2007 2:43 pm
i have both of my nozzles in my intake now one behind the elbow and one in front of the elbow mounted through the intake plate on the head. with the amount of fuel i am movin i gain alot of power on the bottle 5th gear burnouts are no prob but the really nice thing is i dropperd 150 in egt's
ford69557ci
Postby Begle1 » Sun Sep 09, 2007 4:03 pm
Nitrous makes the air coming in denser, which results in the burning of more fuel. Which results in more pressure in the cylinder at any given degree of timing.
So if you're trying to use as much nitrous as possible without blowing a head gasket, you will want to retard the timing.
But whether or not your even close to using as much nitrous as possible depends on where your timing is, what kind of boost pressure you're seeing, and how much fuel you're wasting.
Postby boostedve » Sun Sep 09, 2007 7:15 pm
when adding nitrous do you see a change in boost
boostedve
Postby wannadiesel » Mon Sep 10, 2007 4:14 pm
If you aren't wastegated, yes.
Best dyno: 408/844
wannadiesel
diesel guru
Postby DTanklage » Mon Sep 24, 2007 12:22 am
that is not true
nitrous makes the air more dense and boost will increase
the more you put in the higher the boost will go - if you have the fuel to burn
edit - unless it rips your rear tires off the rims first. if that happens boost will decrease...
rofl
DTanklage
Postby Begle1 » Mon Sep 24, 2007 6:58 am
If a wastegate is set to maintain 30 PSI of boost, and nitrous increases pressure... Provided the wastegate doesn't just get overwhelmed, how would nitrous make it stop working?
Postby TWorline » Mon Sep 24, 2007 5:22 pm
Begle1 wrote:If a wastegate is set to maintain 30 PSI of boost, and nitrous increases pressure... Provided the wastegate doesn't just get overwhelmed, how would nitrous make it stop working?
Maybe it would be laughing to much? :wink:
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby PToombs » Mon Sep 24, 2007 5:26 pm
Tim, you're getting as bad as me! :D You 14mm Rotor! :lol:
Postby TWorline » Mon Sep 24, 2007 5:32 pm
I'm going to consider that a compliment! 8)
Tim Worline
TWorline
Postby DTanklage » Mon Sep 24, 2007 7:27 pm
when you buy a turbo and they get all the details about your truck build it for you and set the wg at 40 psi does it always make 40? no, might make 37 on your truck and 43 on your buddies
if ya change inj does it change your boost?
DTanklage
Postby Begle1 » Mon Sep 24, 2007 7:44 pm
And if my turbo is always making 37 PSI, I don't see how it makes a different number on nitrous?
I have no experience with it, if you say there's an increase I don't have much of a way or reason to argue it. I just don't see how the actuator doesn't see the extra pressure and open the gate farther to compensate.
Postby DTanklage » Mon Sep 24, 2007 8:18 pm
is the afc lever still in your pump?
if not take it out and see if you dont make more than 37 psi
if so put it back in and see if it still makes 37 psi
don
oh - you were just using that number cuz that is the number i was using
got it
how much boost does your truck make now?
DTanklage
