Hey all,
I have about 1500 miles on my old chevy square body crew cab conversion with a NV4500 and 4.10 gears. Runs nice but it has the 21cm2 exhaust housing which is not doing it any favors in performance. I have already added a 3200 gov spring and re-clocked the fuel pin.
I am really wanting it to pull harder off the bottom, it really does not seems to build much boost below 1800 rpm and then its still slow till past 2000rmp. I want to eventually run 5x.012's (maybe 5x.10's even)from SDX. My goals are to get the towing performance where I can pull 10K# confidently.
For the money my upgrade options are BD diesel 16cm2 upgrade housing for $150, or Gillette 18cm2 for $125, Gillette 16cm2 for $195, or other input for a turbo upgrade.
or should I just plan on going with an HX35, will the hx35 perform substantially better than a H1C with upgraded turbo housing?
I know there is information out there, but it all seems tailored toward competition use and that is not in my plans.
thanks in advance for the input.
