thanks fellas, theres a little more than .3 of an inch between the IP and the gear. I'll shove the spare pump back together to get a picture with a real measurment.
I would like to test it... clearly at this point the seal lip is the next thing to blow. But IDK what the dynamics of the test would be...maybe it would act different when it was spinning on the truck instead of just on the bench with airpressure to it...what do ya'll think?
Pete...at least its not my feet
Ellis... making this sucker was nerve racking. If I could make some on a cnc mill it would be best, but the drilling into the VE case was the hardest part. IDK how much room there is, so I only drilled about a solid 1/4 inch hole. then started them with a regular 6-32 tap...then ground the tip off the tap to make a 100% bottom tap...locktighted the 3 small bolts as well
HOPEFULLY (if the dirtbag ever calls me back) i'll be getting a clean d350 soon, If I do, the red truck will get a big big fuel system and I can really see howmuch the seal will hold...and what effects it has on case pressure.
Most ive seen out of this pump is 22 psi now. there is a screen filter downstreem, so hopefully the pump is still in good shape
