Hello guys. I got myself a 91 cummins non intercooled truck and its actaully my dads but he told me I can mod it if i feel the need.... well I feel the need! A buddy of my dads left a wrecked international with the DT466 engine at our house and I want to take some parts.. I'm pretty sure that this engine has a P-pump and the turbo(garrett) down pipe (4in) is bigger than my stock holset.
I thought about using my turbo and then using the other turbo and running a twins set up. but we just rebuilt the getrag and bought a south bend clutch rated for 350 horse and 700 ft lbs. I would love to see those numbers out of my truck. Is it possible of runnin twins and getting those numbers fairly easy? Or is there another way?
O i probably should tell you what I've already done to the truck to do that. turned the pump up a bit and put duel 5 inch stacks but that all for modifications. I know I'm asking for a lot and I've got one more question. I've been looking for injectors also since they are a simple upgrade and quick to do. Which one would be best for good gas milage and power. I pull a bobcat and trailer all of the time so I don't want my gas milage to go down any more cause all that weight doesn't help.
Sorry for asking so much I'm new to the diesel scene and any help would be great
