ahale2772 wrote:those egt's are mega low, you should be much higher than that. Methinks something is wrong with your fuel system/guage/pump if 1100 degrees is your max egt.
I could peg my 1600 degree egt in 3 seconds flat with a "maxed" pump and hx35
a "maxed" pump would be a tid-bit hotter than 1100 degrees
Users browsing this forum: No registered users and 76 guests
