um yah!!
um yah!!
Postby seeker1056 » Tue Sep 11, 2007 7:38 am
dont confuse the amount of oil a 3/8" oil "feed" line can supply with the amount of oil comin out the other side of the turbo through a couple thou bearing clearance!!!
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Begle1 » Tue Sep 11, 2007 8:14 am
Pictures? Please?
hmmmm?
Postby seeker1056 » Tue Sep 11, 2007 11:44 am
how did i get over here from the twins oiling thread?????
Pix - why would I wanna post pix of an oil return line you cant hardly see so you can see a piece of reinforced hose on a T.
I am not here to debate wether you agree or not - pull your own drain line and stick it in a bucket n see for yurself - in flows capability on a 3/8" line , n out flows through a bearing are NOT the same. Period.
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby PToombs » Tue Sep 11, 2007 3:07 pm
Ok, don't get your panties in a bunch! :wink: It's only oil! :D
Postby Begle1 » Tue Sep 11, 2007 4:41 pm
Oh... I was under the impression that you somehow managed to blow oil all over your engine compartment...
Postby dpuckett » Tue Sep 11, 2007 6:23 pm
Begle- I did that on my last turbo swap. Lost 2 gallons of oil in about 30seconds. Used the Dakota to go get more, and extended my drain interval 3000mi. Hey, 2/3 of my oil was brand new, so why not?
Daniel
Postby PToombs » Tue Sep 11, 2007 6:27 pm
That's how I learned! I put in my pyro, without the turbo. I put the hose in the return line and started it to blow out chunks. It blew out all right! :shock: The hose reared up and coated the fender in 2.3 seconds! I only lost about 2-3 qts though. Wow, :oops:
Postby meby » Sat Sep 15, 2007 8:51 am
I was working on my oil pressure sender hose once with the engine running and blew it. It covered my face, that side of the engine compartment, and a lot of my garage wall. :shock: :x Now I know what oil tastes like. :roll: Also gives a whole new meaning to getting a facial. :lol: :mrgreen:
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
