tims cooler tubz
tims cooler tubz
Postby christopherctd » Mon Jan 02, 2012 8:01 pm
i know this has been asked a million times but where do i go to order a set of coolertubz? and not of ebay. thanks.
92 reg cab 2wd fresh 518, s300, 4in exhaust to 6 in stack, 5x016 sticks, modded pump
christopherctd
Re: tims cooler tubz
Postby ellis93 » Mon Jan 02, 2012 8:12 pm
Postby corrtoyz » Sun May 06, 2012 10:52 pm
How good do they work
corrtoyz
Postby ellis93 » Mon May 07, 2012 7:49 am
My egts lowered by 100 while towing,I really didn't notice anything cruising empty,spool up was faster ether way. Notable difference ;)
Postby tampabayBill » Mon May 07, 2012 8:35 am
Ditto
Twins coming soon!
tampabayBill
Users browsing this forum: No registered users and 63 guests
