injectors?
injectors?
Postby jacobwebb57 » Tue Jan 03, 2012 5:22 pm
i hate to be redundant bc im sure what i want to know is on hear somewhere but i can t find it..i wanna know what are the biggest injectors i can run with my truck. how big of injector will an hx35 support (i eventually want to run twins after head studs and head work) so I want something that can keep up with the twins when I get them. and also what kind of fuel pump i should get how many gph?.. i don’t plan on spending the money on an air dog but something along those lines. it has a stock lp the head is stock except for valve springs.. i would like to eventually get about 400 hp.. im guessing im at about 250 hp 550 flb. is that about right? i have never dynode it
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Users browsing this forum: No registered users and 75 guests
