wifes dash at night
wifes dash at night
Postby CAJUN 93 » Sat Jan 21, 2012 8:15 pm
just playing with camera and though i would post a pic (if it works).
daryl
CAJUN 93
Re: wifes dash at night
Postby CAJUN 93 » Sat Jan 21, 2012 8:24 pm
the wires and tubing from the dash pod are normally covered in wire loom thats painted to match. i am in the process of making -4 braided hoses for the fuel and oil pressure to get rid of the plastic tubing. the truck makes over 80 lbs of oil pressure on cold mornings :shock: and i'm pretty sure the plastic tubing isn't designed to handle that. the fuel is only about 6 lbs now but the piston pump should increase that.
daryl
CAJUN 93
Postby ellis93 » Sat Jan 21, 2012 8:29 pm
Wow! :shock: that's a bunch o gauges :lol:
Looks good! 8)
Postby Hansen01 » Sun Jan 22, 2012 8:42 am
n i thought i had a lot of gauges :lol:
i changed all mine to blue, looks good man.
Under construction...
Hansen01
Postby CAJUN 93 » Sun Jan 22, 2012 5:47 pm
thanks ya'll. we took it to gatlinburg in october and they really give me something to do while the wife sleeps in the passenger seat. :) still gotta hook the oil temp guage up, aint had the cohoneis to drill a hole in the oil pan.
daryl
CAJUN 93
Postby moose5.9 » Thu Dec 19, 2013 10:41 am
Very nice! keeping an eye on everything
DD: 99 nissan frontier
sold: 97 F250, 7.3l d60 swap, billet pushrods,elec.fuel, gauges, dual 5inch side pipe,
moose5.9
Postby delsilver » Thu Dec 19, 2013 11:11 am
I don't know if you would get a proper reading off it but there is a spare port in behind the turbo with a plug in it. I am using it to supply oil to my bypass oil cleaner but you might be able to set it up with a temperature sending unit instead of drilling the pan.
The only problem i can see is because it is right in the block you may get the block temp instead of the oil temp.
Del
Delsilver
93 W250
Fuel pin turned 90 deg, starwheel turned down, timing 1/8 adjust
delsilver
Postby moose5.9 » Thu Dec 19, 2013 11:14 am
You could also tee off the stock oil pressure sender on top of the oil filter
moose5.9
Postby CAJUN 93 » Fri Dec 20, 2013 8:11 pm
I thought about tee-ing in but the its a mechanical guage and the probe is big, almost o2 sensor size. I bought the bung for the probe when I bought everything else so I plan to drill a hole and weld the bung to the pan. I've put that off until I move all the gauges to the crew cab 4wd dually project. the engine is out so it will be a lot easier to get too.
Daryl
CAJUN 93
