More Timing questions
Postby rbrettctd » Sun Sep 16, 2007 4:02 pm
Okay does 'to the block' refer to pushing the pump as far as it goes, rather than touching the block actually? Or does it mean the afc cover is close to the block? And for the back nut, do you just get on it with a socket and extension?
Thanks for fixing my timing stupidity. :?
Randy
rbrettctd
Postby NYCEGUY01 » Sun Sep 16, 2007 4:08 pm
I was able to get to mine pretty easy with a s-wrench.
At least on my motor the afc will get close, but not touch before I run out off room in the slots for adjustment.
To get any more advance you will have to move the gear a tooth ( or two as some here have done)
96 chevy 3500 4x4 dually. 1st gen Cummins ,nv4500.
NYCEGUY01
Postby bgilbert » Sun Sep 16, 2007 8:25 pm
You mean close to the cylinder head, not the block. I prefer the $28 snap-on wrench to loosen ALL three of the 13mm pump nuts. I believe it is snap-on part number sp144.
Bill Gilbert
bgilbert
Postby PToombs » Mon Sep 17, 2007 3:31 pm
I prefer my $2 HF wrench I heated and bent! :wink:
Postby nooblet » Tue Sep 18, 2007 12:31 pm
I used a crows foot on a 3/8" ratchet and extension.
Chris
nooblet
Postby dpuckett » Tue Sep 18, 2007 6:38 pm
nooblet wrote:I used a crows foot on a 3/8" ratchet and extension.
Chris
ALRIGHT!!!! :mrgreen: Someone has taken my advice and done that, as well. If'n I had a Mr Sparky, I could heat and bend a wrench myself.
Daniel
