m880cummins wrote:Hi Guys,
fuel screw
Slack taken out of throttle cable
High idle screw removed (allows around 2900 RPM)
m880cummins wrote:High idle screw removed (allows around 2900 RPM)
m880cummins wrote:Well with the screw delete and the 3200 spring it is more like 3500 rpms (getting a tach soon) all I know is it sounds like a Detroit diesel when I flip the valet switch and do a hard 4th gear pull.
Here's yesterday: I consider this a zero buck mod for me because I got the lokar cable for free. Now I get even more throttle travel and gets rid of all the clunky brackets for the throttle (mines a 5 speed so I don't need the kickdown).![]()
Just need to clean up the wiring and spritz some black on the area that was covered by the throttle bracket.
Charlie
