Performance mods for a rock buggy? BACK FROM THE DEAD!
Re: Performance mods for a rock buggy?
Postby oldestof11 » Tue Apr 14, 2015 4:39 pm
Awesome!!!!
Postby 1STGENFARMBOY » Thu Apr 16, 2015 8:39 am
GOOD LORD ! ! ! ! that thing is soooooooo cool.
Postby PToombs » Sun Apr 19, 2015 6:45 pm
I happened to find this video on FB of it, too cool!
https://www.youtube.com/watch?v=bZhxi0w9QaE
Postby Jeep-hauler » Tue Apr 21, 2015 8:10 am
Thanks guys. It's a lot of fun, and so far I haven't been pulled over for lack of fenders (knocks on wood). I'm starting to get the itch for more power though, and still need to install the 366 spring. All of the tamper caps are still on the IP :oops: Not for long though.
'51 Power Wagon VE Cummins project.
'92 W250 -Got it cheap, it runs, it's ugly, it's a parts truck
'93 W250 -tweaked pump, 4" exhaust, NV 4500HD 5-speed. Jeep tow rig, daily driver. Sold.
Jeep-hauler
Postby Jeep-hauler » Mon Jun 01, 2015 9:08 pm
Did the basic pump mods with the 366 spring a couple weeks back. Turned the fuel pin to the deepest side and turned in the power screw a bit. It really woke it up. Currently seeing 35 lbs boost max with egts rarely over 1000, even with the bigger injectors. I may look for a new fuel pin, plus more pump adjustment. Timing is still stock. I like the low end, but I may play around with it.
Also, this showed up in the mail:
8 page spread!
Jeep-hauler
Postby AHineman » Tue Jun 02, 2015 7:52 am
Awesome!
Postby PToombs » Tue Jun 02, 2015 5:31 pm
That's cool!
Postby Jeep-hauler » Sat Jun 13, 2015 12:13 pm
In case you were wondering, not having the 1st gen space around the engine really sucks. It's a tight package, and real bear to get to the IP.
Jeep-hauler
Postby oldestof11 » Sat Jun 13, 2015 3:30 pm
I am going to guess you built the truck around the engine? :lol:
Postby Jeep-hauler » Sat Jun 13, 2015 9:15 pm
oldestof11 wrote:I am going to guess you built the truck around the engine? :lol:
Pretty much, but the front structure does come apart to service the engine/trans. I just recently had it apart for trans repairs.
Jeep-hauler
Re: Performance mods for a rock buggy? BACK FROM THE DEAD!
Postby Jeep-hauler » Tue Jul 24, 2018 9:11 pm
Hey Y'all, it's been a long time since I checked in here, but I could use your help. How high can you spin a VE pump before its damaged? due to silt damage, my engine ran away on me a couple days ago, and it hit some HIGH RPMs before the head gasket thankfully blew. I'm guessing at least 5000 rpm. It was insane, and I thought for sure I was going to watch my truck burn to the ground after it threw the rods out, lol.
Asking to see if the pump would still be good on another engine.
Jeep-hauler
Postby PToombs » Wed Jul 25, 2018 5:23 pm
I run mine to 35-3800 on a regular basis. Just to blow out the soot you understand. ;)
Sounds like you may need a finer fuel filter if you have silt getting in there.
Postby Jeep-hauler » Wed Jul 25, 2018 8:09 pm
PToombs wrote:I run mine to 35-3800 on a regular basis. Just to blow out the soot you understand. ;)
I think my fuel filtration is fine, but I found the air intake boot to the turbo had a good sized hole in it about 800 miles into a Baja race. I have no idea how much dirt the engine ate (the turbo looked sandblasted). I'm attributing the run away to the lack of rings/worn bore and eating its own oil. The block is junk, I just want to know what parts I can keep.
Jeep-hauler
Postby PToombs » Sat Jul 28, 2018 4:14 pm
Ah, sorry! I thought the silt was in the fuel system! That's too bad it blew up on you, most of the bolt on accessories should be ok, pump, starter, vacuum or hydroboost pump.
Postby bensol64 » Thu Nov 22, 2018 8:10 pm
One of the coolest project I've seen. Nice job!
'92 W350 5speed 4x4 with 17" wheels and 33" ironman tires
bensol64
