How to remove metal collar on full power screw ?
Postby cummins32 » Tue Apr 10, 2012 8:55 am
What's the easiest wat to remove it Thanks
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Re: How to remove metal collar on full power screw ?
Postby cmann250 » Tue Apr 10, 2012 10:46 am
I stuck it in a vise (carefully to avoid fubaring the threads), and split it with a chisel. I peeled it off with pliers and backed the nut off to straighten out the threads. It's more proper to carefully go at it with a Dremel tool and straighten out the threads with a tap and die, but oh well :roll: :lol:
Postby Tacoclaw » Tue Apr 10, 2012 11:33 am
Yeah, I think we cut most of the way through mine with a cutof wheel, then split the last bit with a chisel. We used an actual die to chase the threads and threw it back in.
Just make sure you mark where it was at before you take it out.
Postby ellis93 » Tue Apr 10, 2012 12:08 pm
I peeled mine off with a chisel and cleaned the threads up with a small triangle file.
Postby cummins32 » Tue Apr 10, 2012 2:16 pm
Ok so I loosen the locknut and count the turns as I back the screw out, and cut off the collar ? Thanks
cummins32
Postby Tacoclaw » Tue Apr 10, 2012 2:45 pm
Well, I loosened the locknut, then put a paint mark on the threads where the locknut was at once I got enough showing. Then just made sure not to wipe it entirely off.
You can count turns, I just figured I'd lose count while I was dropping the screwdriver 15 times.
Postby cougar » Sat Apr 14, 2012 8:27 pm
Count the number of screw driver drops instead, should be close enough :mrgreen:
01 2500 "the work truck".
cougar
Postby Kasper Cummins » Sun Apr 15, 2012 8:08 am
I used the nut to push the collar off, it took very little force to do. Then there was only one spot (maybe three treads) where I could tell it was welded or tacked on.
92 W250 club cab
Kasper Cummins
Users browsing this forum: No registered users and 66 guests
